New Member/Forza Rear tyre recall
Posted: Fri Jun 13, 2014 6:09 pm
by Bigboss242
Hi I am a new member just picked up the forza last night. This morning rear tyre is flat and air leaks from the valve steam anyone aware of a recall?
Re: New Member/Forza Rear tyre recall
Posted: Fri Jun 13, 2014 6:21 pm
by Bigboss242
How do I remove the rear wheel can anyone help?
Posted: Fri Jun 13, 2014 6:54 pm
by kramnala58
Hi, welcome to hondapcx.org
Did you buy your Forza new? If so, I would call the dealer and have them sort it out.
Posted: Fri Jun 13, 2014 7:50 pm
by Bigboss242
I got it figured out managed to run over a nail on the first day.
Posted: Fri Jun 13, 2014 8:16 pm
by The Mantis
Boy, that's some rotten luck!
Posted: Fri Jun 13, 2014 8:28 pm
by willajabir
I called the dealer and they claimed 1 hr to remove and another hr to reinstall the rear tire. He did say he was guessing as they haven't changed a rear tire yet.
gn2 has changed a rear and said it was pretty simple. Maybe he can give some feedback.
I have the manual if you can provide a way to send the 2 pages to you.
Posted: Sat Jun 14, 2014 2:46 am
Removal should not take more than ten minutes and that's generous.
I had a puncture repair done on mine, the whole job from start to finish was billed as thirty minutes.
Posted: Wed Jun 18, 2014 5:23 pm
by Bigboss242
Had family fix the puncture took less than 5 minutes.
Posted: Wed Jun 18, 2014 7:04 pm
That's extremely fast for a proper repair.
Was the tyre taken off the rim, inspected and plugged properly or did you just use an emergency kit and hope for the best?
Posted: Wed Jun 18, 2014 10:41 pm
Can't be. Not in five minutes. Oh, that makes me nervous and I'm all the way over here!
Posted: Thu Jun 19, 2014 6:18 pm
by Bigboss242
Used a tire plug kit/repair. I don't trust it. I wan't to get a new tire as soon as possible. Inspected the tire a small bump but besides that it seems fine ridden a few miles on it. Even crashed my bike coming home from work. My fault not the tires. Not sure how much repair will be on the right side its not too bad.
