Need full pcx plastic pieces(white-2013)
Posted: Tue Jul 15, 2014 12:12 pm
by toubanosxr
Hi...I am here.
I had an accident and the most plastic pieces is broken-burn..or black skin from the road..
Please do you know any cheap site to buy them all?Like set or something..
Thanks :?
(sorry for my english)
Re: Need full pcx plastic pieces(white-2013)
Posted: Tue Jul 15, 2014 12:46 pm
What is your location? I have found parts fairly cheap from partzilla.com and Bikebandit.com
Posted: Tue Jul 15, 2014 1:25 pm
by toubanosxr
Greece, Thanks :)
Posted: Tue Jul 15, 2014 1:29 pm
by toubanosxr
other site please??
Posted: Tue Jul 15, 2014 1:48 pm
by JoshM
Have you contacted your Honda dealer? They should have access to all pieces.
http://www.powerbypcx.com/ also has all the plastic panels.
Posted: Tue Jul 15, 2014 8:40 pm
Did I happen to mention that the panels for 2011 pcx 125s fit the 2013 pcx 150? Only in the 2014-2015 model did they change the parts so significantly that they can not be interchanged with previous year models. I replaced multiple panels on both of my 2013 pcx 150s with 2011 parts from partzilla.com and bikebandit.com.. Consider that and you will find the parts for the older pcx to be much cheaper. If you are afraid that they might not, then order only one or two parts from them and try them on first. The only panels that may not fit are the ones that are black/ not painted. Look for the color code under your seat and then look for that code on the many versions of the part at those sites. They will be distinctly marked on the micro fiche.
