Page 1 of 2
Scoot won't start...Please Help
Posted: Mon Sep 29, 2014 3:02 pm
by dmiles13
Hello All,
So scoot hasn't been ridden in a few weeks and now it won't start. I attempted to hook up trickle charger to battery but can't access the battery. There doesn't seem to be any visible screw to loosen the hatch. Please help!
Thank you!
Re: Scoot won't start...Please Help
Posted: Mon Sep 29, 2014 8:25 pm
by GeorgeSK
I asked that question once...
http://www.hondapcx.org/viewtopic.php?f ... t=+battery
Easy once you see the picture that Maddiedog put in about twelve posts down.
Posted: Mon Sep 29, 2014 9:11 pm
by dmiles13
Thanks George! That was easy. Do I have to remove the battery from its compartment or can I connect the charger to it where it sits? Sorry for the dumb question, but this is a first. My Vstar had a plug that just attached to the charger.
Posted: Mon Sep 29, 2014 11:08 pm
by ScooterMan
u can connect it staight to where it sits...just don't hook it up backwards if you do it that way. I do it on the bike/car all the time.
Posted: Tue Sep 30, 2014 2:56 am
by iceman
dmiles13 - how old is your bike? do you use idle-stop a lot (if the 2013 version onwards?) - people indicate the original battery if a good one should last many years and go a month or so without charging.
Posted: Tue Sep 30, 2014 9:20 am
by kcpcx
You can charge the battery without removing it.
I recommend an Optimate charger. If you're going to leave the scooter sit for more than a week unused, attack the charger leads and just let the charger plugged in to trickle charge the battery.
I've owned several charger / maintainers, and this one is the best in my opinion. I've even revived a couple of sulfated batteries using it.
http://www.amazon.com/OptiMate-5-batter ... B004PPXZJ4
Posted: Tue Sep 30, 2014 10:19 am
by iceman
Thanks for that, been looking around for a good charger and this seems to be suitable for car batteries as well as bikes. Odd the PCX battery needs charging so often, people have stated theirs lasts for ages when not in use without the need for a top-up.
Posted: Tue Sep 30, 2014 11:16 am
by kcpcx
By the way, there are several generations of Optimate chargers out there, and I think they all work about the same. I think mine is the 3 or 4, can't remember. I'd find the one you can get the best deal on, i.e. I wouldn't worry about buying the latest 6th gen unit if I could get the 4th gen for $20 less.
I've found over the years that motorcycle batteries are far more fragile than auto batteries. Probably makes sense since the car batteries are many times larger and hence have a lot more reserve capacity.
Small batteries like the ones in our PCX will punish you if neglected. One of the biggest mistakes motorcycle owners make is just parking the bike in the garage for extended periods. Winter, for example. A sure way to end up buying another battery in spring.
You can easily get a small SAE connector and attach it to the battery terminals on the PCX. Then, anytime you are going to leave the scoot for an extended time, just plug in the Optimate. It will charge it to the proper level automatically and then shut down into monitor mode until the battery needs charged again.
Connector:
http://www.amazon.com/Battery-Tender-08 ... B000NCOKZQ
Posted: Mon Oct 06, 2014 5:06 am
by riderthailand
The battery especially on the old PCX's need replacement every year or so. The new models have improved.
Posted: Tue Oct 07, 2014 1:54 pm
by ScooterMan
riderthailand wrote:The battery especially on the old PCX's need replacement every year or so. The new models have improved.
Prob due to idle stop and rougher roads. Heat and vibration kill batteries, along with frequent discharging (using idle stop feature). My 2015 has a larger battery that is 2lbs heavier to compensate, and yet still the USA model doesn't even have idle stop. Honda prob just didn't want to source an 2nd battery and design two different battery box covers or boxes for such a limited US market. I ordered a Li Ion battery for "Scooter USA Parts" for about $62 shipped. Already run one in my 2015 PCX, and had to re-order a 2nd one since I took it out of my 2013 to put in the new scoot. I can definitely feel the weight difference of the 12lbs or so I've removed when I sit on the bike and tilt it side to side. That 12lbs up a 4-6 degree grade at full throttle could mean an additional mph! I'll take what I can get. =)
Posted: Tue Oct 07, 2014 5:41 pm
"The battery especially on the old PCX's need replacement every year or so."
Bullshit.
Batteries don't like lots of starting and short journeys.
The battery on my 2010 PCX was left uncharged and the scooter left uncovered outdoors and not started for periods of up to three months in freezing winter temperatures and always started first time for the three years I owned it.
Maybe that's because it hardly ever did any journeys of less than ten miles and the idle stop didn't kick in unless it was on a 27 mile journey and even then it was less than a handful of times per trip.
Posted: Wed Oct 15, 2014 6:50 am
by little_mouse25
Hello,
I've been having a similar problem - I was away for 4 days and my Honda PCX 125 would't start... It ignites, the lights go on (so I can see the panel) but that's about it. It just wouldn't start, it sits quiet. I do however have to say that when I tried it the first time, there was a noise that indicated it's about to jump but then nothing. When I tried to start it again and again, sometimes the dashboard would just go into yellow so I wouldn't see the display. This happened twice. I suspect it might be the battery, after reading all previous posts. Or what do you reckon? I park it outside and I live on 2nd floor so I don't know how I'd charge it unless I took it to the garage which I'm trying to avoid for obvious financial reasons (unless of course I'd find the battery, took it out and charge it in my flat). The thing is, I'm a girl and am happy to leave my bike to get repaired as I don't even know where I'd start but still, I wanted to see if there's anything I could do to get it started and working again myself. I live in London, commute on it every day, 8 miles each way. Thank you.
Posted: Wed Oct 15, 2014 9:19 am
by Alibally
Hello. Is it still under warranty? If it is I'm sure you get breakdown cover with it. I did anyway.
Posted: Wed Oct 15, 2014 1:15 pm
I use a battery tender on mine and have those leads permanently attached like kcpcx pointed out. If your battery goes completely dead while the bike is sitting outside, you CAN jump start it from a car, though it isn't recommended. I have jump started several scooters. The best way to jump start them though is with a battery pack that most motorcycle shops have. Also, if you live outside of the United States you probably have an idle-stop switch. If you don't ride very far but use the switch a lot you will run your battery down. It takes about 10 miles of riding to recharge a battery back to what it was before you started it initially. When you start the engine it takes a bit out of the battery. If you drain it over and over without giving it an opportunity to recharge, it won't take long before it just doesn't have enough left in it to turn over the engine, even if it can turn on the lights.
Posted: Wed Oct 15, 2014 3:01 pm
by little_mouse25
Alibally wrote:Hello. Is it still under warranty? If it is I'm sure you get breakdown cover with it. I did anyway.
Hello, it is no longer under warranty unfortunately. I called my garage and they confirmed it's definitely the battery. I just saw a video of how to remove the battery - please would you be able to recommend what do I need to buy in order to recharge it at home? Thank you.
Posted: Wed Oct 15, 2014 3:09 pm
by little_mouse25
Mel46 wrote:I use a battery tender on mine and have those leads permanently attached like kcpcx pointed out. If your battery goes completely dead while the bike is sitting outside, you CAN jump start it from a car, though it isn't recommended. I have jump started several scooters. The best way to jump start them though is with a battery pack that most motorcycle shops have. Also, if you live outside of the United States you probably have an idle-stop switch. If you don't ride very far but use the switch a lot you will run your battery down. It takes about 10 miles of riding to recharge a battery back to what it was before you started it initially. When you start the engine it takes a bit out of the battery. If you drain it over and over without giving it an opportunity to recharge, it won't take long before it just doesn't have enough left in it to turn over the engine, even if it can turn on the lights.
Hi Mel46, I can't jump start it from a car as I don't have one. Would you be able to recommend what exactly do I need to buy to be able to recharge it at home? I don't use idle-stop anymore as it died on me at traffic lights once and I'm too afraid to risk it even though I had the bike fully serviced recently. I just saw a video of how to remove the battery so I am now confident I could do it myself having the right equipment but I have no idea what I need to get. On this forum I came across the battery tender but how do I connect that to the power? Sorry - I may seem very blonde here but truly this is very new to me and I'm keen to get it sorted without having to pay recovery team to take my bike to the garage which I would have to pay for. I'd rather buy the battery charge kit and have it handy should anything similar happen again. Thank you.
Posted: Wed Oct 15, 2014 3:51 pm
by DAB
Get one of these.
http://www.halfords.com/motoring/motorc ... 5-amp#tab3
Take the battery out and charge it inside. Should have full instructions.
Posted: Wed Oct 15, 2014 3:59 pm
by SECoda
Do you mainly use the tender in the winter? I am tired of replacing dead (shorted) fairly new batteries from lack of use - especially in my ATV's.
Posted: Wed Oct 15, 2014 4:07 pm
by little_mouse25
DAB wrote:Get one of these.
Hi Dab, thank you, thank you, thank you!!!! It looks like that is exactly what I need! I will let you know how I got on!
Posted: Wed Oct 15, 2014 5:53 pm
by kcpcx
I use a tender when a bike will be parked for more than a week or two, unridden.
