clutch sound... help?
Posted: Wed Oct 01, 2014 3:20 pm
by danieljw
seems my scooter has developed a 'weird' sound from the clutch, sort of sounds like a 'dry bearing' sound, more noticeable when warm, dose anyone else have this?
Re: clutch sound... help?
Posted: Wed Oct 01, 2014 5:59 pm
by buddy1976
daniejw wrote:seems my scooter has developed a 'weird' sound from the clutch, sort of sounds like a 'dry bearing' sound, more noticeable when warm, dose anyone else have this?
Yes there is a quite a few having this problem check out this thread including me, check out this thread, I will be fitting my new bearings tomorrow I'll be posting my results
Posted: Wed Oct 01, 2014 8:51 pm
Yep, looks like you are beginning to hear what we have been having problems with. Buddy1976, you forgot the link. Here is the thread.
http://hondapcx.org/viewtopic.php?f=2&t=3136
Good luck. The whole part is easier to replace than taking it apart and trying to replace that bearing.
Posted: Thu Oct 02, 2014 12:52 am
by iceman
You mention 300 miles - is that all? Is the bike covered by warranty?
Posted: Thu Oct 02, 2014 2:45 am
by danieljw
yes covered by a warranty, I'm going to drop to drop my child of at play school and them head straight to the honda dealer.
Posted: Thu Oct 02, 2014 3:38 am
by buddy1976
Whoops, my bad lol thanks mel
Posted: Thu Oct 02, 2014 5:08 am
by danieljw
been and now I'm back, i have been told what i am hearing is the belt going around the pulley, i was told its normal, and will sound slightly louder now as everything is broken in a lot more than when new, and not to worry, he said out off the 100's of pcx's they have sold that have had to change only 1 bearing in the clutch!.
Posted: Thu Oct 02, 2014 11:15 am
Hmmm....one here and one there add up. I know of several who have had this clutch problem. However, since your bike only has 300 miles on it, it won't even break in until close to 2,000 miles, so just monitor the sound and ride. If it sounds really bad after a while instead of better, then take it back to the shop. Ours just got worse, while the dealer seemed to have worse hearing. Even when it was about to lock up he said that it sounded normal, though the rest of the world was asking what was wrong with our bike. We ended up going to another dealer to get it fixed. Hopefully, and I emphasize 'Hopefully', the sound on yours will improve as the parts seat.
Posted: Thu Oct 02, 2014 2:06 pm
by danieljw
thankyou for your input, yes my bike now has around 350 miles so its unlikely to be a bearing i would think, the dealer said keep an eye on it until the 600 mile service, but he said all pcx's sound exactly like mine!
Posted: Sat Oct 04, 2014 11:04 am
by buddy1976
danieljw wrote:thankyou for your input, yes my bike now has around 350 miles so its unlikely to be a bearing i would think, the dealer said keep an eye on it until the 600 mile service, but he said all pcx's sound exactly like mine!
Try spinning the rear wheel backwards whislt scoot is running in idle on the centre stand, if the noise gets louder it will most likely be the bearing problem.
Posted: Mon Oct 06, 2014 5:00 am
by riderthailand
Try using some WD 40 on the clutch as it helped me with this
Posted: Tue Oct 21, 2014 8:17 pm
by dem0nk1d
http://hondapcx.org/viewtopic.php?f=2&t=2980
more details here... at least a little more in-depth
Posted: Wed Oct 22, 2014 10:47 am
by ScooterMan
Can't help but wonder if the additional holes you have drilled in the clutch cover might have contributed to the failure by allowing in additional elements. Although that wouldn't ecplain Mel46's failure. So the question is, is this a faulty bearing issue, or a debris/contaminant issue to blame?
Posted: Wed Oct 22, 2014 11:11 am
by dem0nk1d
The needle bearing is shielded from all elements because two things. It’s incased by the rear Torque Driver, and there is a top sealed bearing at the top. If it was open you would lose a great deal of grease. So that can’t be the issue as other folks are having the same issue. I could tell you it’s from just driving a ton of miles in a year. I think I got my PCX back in Feb with 2903 miles, today it’s around 12k if not more… Since I moved to Escondido I am driving 1200 miles a month just to work and back home.
I’m going to contact Honda parts as soon as, one of these stores open up. Looks like everyone opens at 10am, which I think is crazy!
Posted: Fri Oct 24, 2014 3:18 pm
by ScooterMan
Just so everyone knows, or those following this thread...I checked the parts fiche for the bearing in question and it's the same part # for 2013 and 2015 models. So, 2015 owners may not necessarily be safe.
Posted: Wed Jan 28, 2015 1:40 pm
by KrisoUK
Hey guys, I get some weird noise and vibration just when I'm taking off till 5-10 miles. It's like some metal is hitting another metal, can't really describe it, but you can feel strong vibrations. Then when I'm about to stop, you can here similar noise, but this time it's like something is banging twice or three time and that's again between 10-5 miles range.
Could it be the same reason as you are stating here? My bike is on 13 000 miles and I haven't changed anything apart from oil, drive oil, spark plugs and a filter.
Thank you and Regards.
Posted: Sun Feb 01, 2015 9:36 pm
by frog13
May be time for a new belt ?.
Posted: Mon Feb 02, 2015 12:06 pm
First change your belt. Then listen for the sound by spinning the rear wheel backwards. If it is still there, time to change the bearing assembly. Ours started to really sound loud at 10,000 miles. Just be aware of that.
Posted: Tue Feb 24, 2015 1:19 pm
by dem0nk1d
Sorry guys it's be sometime i have said anything worthwhile. But i can confirm that PART #19 in the rear torque driver is the bearing that fails.
19 91002-GA7-701 BEARING, RADIAL BALL (6902U) (NTN) 1
19 91009-KVY-961 BEARING, RADIAL BALL (6902U) (NSK) 1
My thoughts why it fails, is because the inner side is open and just packed with a very heavy white grease. When that grease dries out, the bearing gets hot and can get contaminated with belt dust, and grit. I finally got around to replacing #19 on the parts diagram of the clutch system, and there was a huge difference in sound. Also you’ll have to remove needle bearing which I usually pound out with an 3/8 extension for a ratchet and replace it with a new one.
18 91001-KCW-003 BEARING, NEEDLE (20X29X18) (NTN)
18 91109-KVY-901 BEARING, NEEDLE (20X29X18) (SCHAEFFLER)
Posted: Fri Mar 11, 2016 1:34 pm
by Tonyx
Sorry to raise an old thread - I always try to resurrect vs starting a new one:)
So there are two choice for both bearings 18 and 19. Which one is the correct one? Why is there big price difference between the bearing suppliers?
Am I correct to assume the bearing 18 is pressed in but bearing 19 will slide out if the circ clip(no. 23 on the diagram) is taken out first?
