I'm just trying to get a list of problems that are typical to the forza 300 as my Warantee is up in feb -2015 and due to the weather in canada will probably stop driving in early November , here are some of the problems #I have 1 speedo inaccurate reads 8 kph to high ( and will only get worse as my tires wear as they will get smaller and turn faster) #2 rear foot pegs one doesn't stay in fully up position( this is due to improper lock position of ball and spring and hole location)# 3 left front panel ,the one by your left knee on page 2-14 of repair manual( called front side body cover)came loose clip holding panel was broke and got worse as I use a leaf blower to dry the scooter and more clips broke.#4 when starting cold starter makes a funny noise (starter drive hangs up)#5 seat gas support to hold seat up is getting weak as on cold days seat falls down. If you have other common problems it would be good to hear them so we can all get them rectified before our Warantee runs out.
Don
Problems with forza 300
Re: Problems with forza 300
I guess the fuel pump recall can be added to the list.
Leaky water pump mechanical seal
Sticky rear caliper warps disc
Exhaust rusts like a rusty thing
