Page 1 of 2
Optimum Garage Humidity
Posted: Sun Dec 21, 2014 1:35 pm
Any thoughts on what this should be? Presumably there will be a max and a min?
Re: Optimum Garage Humidity
Posted: Sun Dec 21, 2014 2:18 pm
Just leave the door open and it will sort itsself out.
Posted: Sun Dec 21, 2014 2:25 pm
by DAB
Don't think the actual humidity is so important, but the change in temperature/pressure which will cause condensation.
Posted: Sun Dec 21, 2014 4:48 pm
gn2 wrote:Just leave the door open and it will sort itsself out.
In Yorkshire?
Posted: Sun Dec 21, 2014 4:52 pm
by DAB
It's Yorkshire, likely to get nicked!
Posted: Sun Dec 21, 2014 5:19 pm
Or shagged.
Posted: Sun Dec 21, 2014 5:39 pm
by oldbiker
There might be a point in leaving the door open, more likely to dry your bike. Logically if you put a wet bike in an enclosed space the water must either stay on the bike or air, unless you use a dehumidifier. I let mine dry naturally outside plus when it rains it washes the salt off. Plus I have the self cleaning black pcx
Posted: Sun Dec 21, 2014 5:46 pm
DAB wrote:gn2 wrote:Just leave the door open and it will sort itsself out.
I doubt if Yorkshire will ever be nicked.
Did you go to school?
Posted: Sun Dec 21, 2014 5:52 pm
oldbiker wrote:There might be a point in leaving the door open, more likely to dry your bike. Logically if you put a wet bike in an enclosed space the water must either stay on the bike or air, unless you use a dehumidifier. I let mine dry naturally outside plus when it rains it washes the salt off. Plus I have the self cleaning black pcx
The garage will be closed pretty much all winter so no wet bikes in and out. I can control the humidity but haven't bothered until now. Temperature is a pretty constant 13c but humidity varies between 50 and 69%. Sounds high to me.
Posted: Sun Dec 21, 2014 6:06 pm
by oldbiker
Humidity currently 81 per cent here and it is not raining according to my weather station so not high.
Posted: Sun Dec 21, 2014 6:10 pm
by DAB
you you wrote:DAB wrote:gn2 wrote:Just leave the door open and it will sort itsself out.
Yup and it was approved
Posted: Sun Dec 21, 2014 6:42 pm
2yous...In my garage today thinking about the moisture too. Not liking it. Scoot is not covered, my choice (I have one though). We are starting winter now. Snow, rain humidity way up. Humidity gets in the garage every time the door gets raised (and more often when it snows when I reach in for shovels, etc).
So, is it an electric heater or dehumidifier the answer? Or neither?
Posted: Sun Dec 21, 2014 8:21 pm
by DAB
WhiteNoise wrote:2yous...In my garage today thinking about the moisture too. Not liking it. Scoot is not covered, my choice (I have one though). We are starting winter now. Snow, rain humidity way up. Humidity gets in the garage every time the door gets raised (and more often when it snows when I reach in for shovels, etc).
Neither.
Posted: Mon Dec 22, 2014 11:58 am
by oldbiker
Posted: Mon Dec 22, 2014 12:12 pm
oldbiker wrote:the bike is immaculate and only gets a cold water bath to clean the grime off once a week.
That's far too often, once every three months is plenty
Remember to use the old ACF-50
Posted: Mon Dec 22, 2014 12:49 pm
by oldbiker
Thanks gn2 not come across afc 50 will give it a try. Can you use it on the ally on the transmission were it gets hot, and on the front discs inner if I mask off the friction surface. Thanks in advance.
Posted: Mon Dec 22, 2014 3:11 pm
Well I went to a RAF school
(Rough As F***)
Posted: Mon Dec 22, 2014 5:46 pm
by frog13
Humidity is important regarding bike care , if you can afford it . Static air isn't good .
Posted: Mon Dec 22, 2014 5:53 pm
A PCX is a cheap disposable utility vehicle, not some priceless work of art.
Leave the effing thing outside, saves you the bother of taking it in and out the garage
Posted: Mon Dec 22, 2014 6:14 pm
gn2 wrote:A PCX is a cheap disposable utility vehicle, not some priceless work of art.
But I've got a garage
And other stuff in it. Just wanted to know what wouldn't be damp in terms of humidity
