honda pcx stop start technology
Posted: Wed May 06, 2015 10:53 am
by marktilley160
the stop start technology on my Honda pcx as stopped working don't no why does anyone no why please
Re: honda pcx stop start technology
Posted: Wed May 06, 2015 12:10 pm
by ScooteringAbout
Your battery may be wearing out, if I understand correctly the PCX has a system to avoid using stop start, if the battery is not charging 100%.
Posted: Wed May 06, 2015 12:49 pm
Only the new version has that intelligent feature, the 2011 model will let the battery die.
Make sure the handlebar switch is in the correct position and check the seat switch.
Posted: Wed May 06, 2015 1:29 pm
by iceman
When you say stopped working, do you mean your bike does start and ride ok but the idle-stop function does not kick in as usual - or you just have problems starting?
Posted: Wed May 06, 2015 1:44 pm
by ScooteringAbout
gn2 wrote:Only the new version has that intelligent feature, the 2011 model will let the battery die.
Ah my bad, didn't notice he had listed his year
Posted: Wed May 06, 2015 1:59 pm
by marktilley160
when I stop at traffic lights it just keeps going wont cut off as normal
Posted: Wed May 06, 2015 2:26 pm
by RideLondon
Is the 'A' light on?
Posted: Wed May 06, 2015 2:28 pm
by iceman
Well, on the bright side - that is the best thing of the two options - better that the bike does work. Hmm, as the slightest tough should start the bike with idle stop engaged, I wonder if the accelerator cable / idle is too tight / too high? Not sure if that is part of how it works.
Posted: Wed May 06, 2015 3:08 pm
by marktilley160
no the A light isn't on going to buy a new battery but not sure on the dimenions of the battery
Posted: Wed May 06, 2015 4:38 pm
Are you absolutely sure you haven't switched it off?
Posted: Thu May 07, 2015 2:20 am
by abcdarko
Also check for the temp sensor, the system doesn't work while engine is cold.The diagnostic tool should show why.
