Added a Few Accessories Today!
Posted: Sun Nov 01, 2015 9:19 pm
I picked up a Sweet Set of XSpeed Red Forza Covers, for the Crankcase & Variator, from Branyers14 the other day. They came in Fri or Sat. THANKS BRANYERS 14!!!
Here are a few Pics:
There were two pieces, the Crankcase Cover and the Variator Cover, and ..... No Instructions. The Power By Forza Website, states that it, FITS OVER. That's about all of the Instructions that come with it! The third Pic above, shows the Stock Black Forza Crankcase Cover, sitting on the floor. The XSpeed Cover is a Direct Replacement for the Stock Cover. However, you DO have to remove the 3 Metal Spacers and Rubber Grommets from the Stock Cover, and swap them over to the XSpeed Cover. The Cover fits perfect on there, and the Stock 3 Bolts are used to Re-Install the Cover to the Crankcase.
One other difference with the Stock & XSpeed Cover, is the Thick Foam on the inside of the Stock Cover. There is No Foam on the inside of the XSpeed Cover. While the 3 Bolts are tightened against the 3 Metal Spacers, there is a small wiggle with the XSpeed Cover, due to No Foam. I didn't have time today, but I'm going to start it up tomorrow, and see if there is any Vibration or Rattling Noise, coming from the Cover. If so, then I'll take a run over to Lowes, and grab some Foam like the one inside of the Stock Cover, and duplicate its positioning inside of the XSpeed Cover. No big deal, just FYI, for those of you wanting to Buy this Kit.
Next the Variator Cover. This is NOT a Direct Replacement like the Crankcase Cover. The Variator Cover actually Installs OVER the Stock Variator Cover. If you'll note the Fourth Pic above, you'll see the Variator Cover Installed. Look just above the Crankcase Cover, at the Black Plastic Section, with the Large Screw in it. The Diagonal Line, just to the Right of the Screw, is where the CVT Filter Cover separates, with the Variator Stock Cover. It all comes off in one piece. That's why you can't do a Direct Replacement with the Variator Cover.
Now, another FYI..... Since you're fitting the XSpeed Variator Cover over the Stock Variator Cover, the Bolts will not be long enough to Re-Install. The Longer Stems on the XSpeed Cover, add some extra Length, requiring Longer Bolts. Here's a Pic of the Bolts I picked up at Lowes this afternoon.
You can see the Black Stock Bolt on the Left, and the New Longer Bolt on the Right. The New Bolt has a Phillips Head, while the Stock Bolt has a Hex Head.
Here's a Close-Up, of the Replacement Bolts you'll need. There are 2-Per Pack, so you'll need 2 Packs to replace your 3 Stock Bolts.
Since it didn't take too long to do the Cover Install, I installed my Givi Rack, and strapped a Cortech Dryver Bag on the back, to hold my Bungee Straps, Velcro Straps, Bungee Net, and several other Non-Expensive items that I didn't want to fill the Trunk with. My Jacket, Gloves & Ballcaps will go in the Trunk, so I don't want to clutter it up with Common Items.
The Dryver Bag holds its shape, and isn't floppy like regular Soft Luggage. I'm going to order a Givi E370 Top Case, and since it's a Monolock Case, it'll fit the Givi Rack I installed today. I'll use the Givi Case, if I'm packing extra gear, or grabbing something at the store. Easy swap out between the Dryver Bag and Givi Case. My Raingear & Windbreaker Jacket Liners, are stored in the Biker's Friend Roll Bag, that I'm using as my Backrest.
Cheers!
BB
Cheers!
BB
