Page 1 of 2
Big guys on PCX125
Posted: Sun Jan 31, 2016 2:42 am
by ThePerkster85
Hi,
I am looking to pull the trigger and order a PCX today, i love the white.
I am a big guy, i have had 125 before that have been fine - what is the PCX like in terms of weight? i have seen the maximum weight and i am way under, but will it significantly reduce speed?
Thanks
Col
Re: Big guys on PCX125
Posted: Sun Jan 31, 2016 4:01 am
by kramnala58
Your body weight won't reduce the speed much, but body mass likely will. The larger your body, the greater the wind resistance. A taller windscreen can help with that.
I am 6'1" (185 cm) and 210 lbs (95 kg)
Posted: Sun Jan 31, 2016 5:22 am
by zanggerk
Hi Col,
how big are you?
I am 6'2", 185 lbs (1.88m, 85kg) and I love riding the PCX. I have a larger than stock windshield. The maximum speed that I can get is quite typical for a PCX (110 kmh, 68 mph on the display) and I am also quite happy with the acceleration- above ~80kmh it gets slower, but that is also quite typical I guess.
There is also plenty of leg room even for someone my size.
Go for it!
Klaus
Posted: Sun Jan 31, 2016 3:29 pm
zanggerk wrote:Hi Col,
how big are you?
Go for it!
Klaus
Puny earthlings
Posted: Sun Jan 31, 2016 3:43 pm
by homie
kramnala58 wrote:Your body weight won't reduce the speed much, but body mass likely will. The larger your body, the greater the wind resistance. A taller windscreen can help with that.
Um... I don't know about this, having some trouble imagining this guy keeping up with me
Posted: Sun Jan 31, 2016 4:15 pm
Looks like he won't have to worry about being pulled over for speeding. :-)
Posted: Sun Jan 31, 2016 5:39 pm
homie wrote:kramnala58 wrote:Your body weight won't reduce the speed much, but body mass likely will. The larger your body, the greater the wind resistance. A taller windscreen can help with that.
He might downhill...
Posted: Mon Feb 08, 2016 12:48 pm
by marcdman4000
Im 6'2" 270lbs. I hit the limiter at 65mph on my 2016 PCX150. took it on a long stretch on imperial highway yesterday. It just takes longer than I would like to get to 65mph.
Posted: Sun Nov 06, 2016 4:24 pm
by JustPassinThru
It's an old thread, but I came across it.
I'd gotten a great deal on a 2011 125...a thousand bucks and 1500 miles. Older guy who was giving up riding entirely.
I'm six-two and 250. I fit okay with a pad on the seat and the butt-stop removed; but there's the occasional bump that makes me wonder what's going on on the chassis.
It was only when I was cleaning out the storage box that I saw the sticker giving the maximum load: 225 pounds. Well, it's too late; but I can get it up to about 53 mph, measured by GPS; and fuel mileage is every bit what I expected. Over 100. So...I'm not giving it up.
I like the light weight; I like that the wheels are an inch bigger than the Burgman 400; I like its balance. It's a great city bike, if I don't break it with my bulk,
Posted: Sun Nov 06, 2016 5:23 pm
by flyingzonker
JustPassinThru wrote:It's an old thread, but I came across it.
You will probably be OK. But, just to be sure, you can get heavy duty shocks, like these:
http://www.motorcycle-superstore.com/32 ... mer-shocks
Posted: Sun Nov 06, 2016 6:10 pm
Don't worry about it, it'll be fine
Posted: Sun Nov 06, 2016 7:48 pm
by GeorgeSK
You might need a belt at 10,000 miles instead of 15,000. A small price to pay. Ride on and enjoy.
Posted: Mon Nov 07, 2016 1:32 am
GeorgeSK wrote:You might need a belt at 10,000 miles instead of 15,000. A small price to pay. Ride on and enjoy.
I don't think he needs a belt
Posted: Mon Nov 07, 2016 1:50 pm
such a quick thinker! You got wit 2yous!
Posted: Sat Dec 02, 2017 1:29 am
by JustPassinThru
flyingzonker wrote:JustPassinThru wrote:It's an old thread, but I came across it.
Again, a long-dead thread.
I have the PCX, still. Considered replacing it, but only because my garage is getting too full.
But...the above link, I tried it, last spring...item is discontinued.
It matters, because I'm considering an off-season Blue Highways tour. I'm about 250 miles from the Pacific Coast, and considering a holiday trip to SoCal or Mexico. The PCX isn't ideal, except that it's comfy in traffic, and reliable as a brick. And, given the cheap price I laid out for it, expendable.
But I need beefier rear struts. I'll be carrying the usual gear...clothes; coats, bedroll; tent. I have a way to rig a milk crate to the rear; but even unloaded, I bottom out on it.
Posted: Sat Dec 02, 2017 9:04 am
by GeorgeSK
Tough call. You can find replacement shocks from Asia, but they would clearly be a bit of a crapshoot, especially if designed for the local population. I'm sure there are heavy Thai folks, but I expect that the manufacturers will be targeting the bulk of the population. Still - You could try. Here is a link to get you started:
http://www.powerbypcx.com/en/52-comfort-pcx-v3
Another possibility would be to contact Ohlins and discuss your application. Probably more money, but if they could make you what you wanted it would be worth it. Here is a starting point:
https://www.ohlinsusa.com/suspension-pr ... %2BScooter
Good hunting, and glad to hear that you are still PCX'ing about.
Posted: Sat Dec 02, 2017 10:39 am
by JustPassinThru
Does the PCX 150 strut fit?
Either the stock, or an upgrade designed for the 150.
Posted: Sun Dec 03, 2017 6:07 pm
by lillypinkjenny
Damn!
Did anyone else look at the title of this thread and think that it might contain some NSFW imagery?
OK ... just my dirty mind then!
Posted: Sat Dec 09, 2017 10:33 pm
by eggman
im right at 800 pounds and im full of nachos and oreos i can almost get up to 27 mph
Posted: Sun Dec 10, 2017 3:56 am
lillypinkjenny wrote:Damn!
Me too. I get people meeting me for the first time and they say."you're big".
And I say "how do you know, I havent had my pants down yet"
