brake caliper adapter
Posted: Tue Mar 01, 2016 3:18 pm
by troy
Hello! Do anyone of a place that makes a brake caliper adapter for a
Honda pcx150 with a 260mm rotor. Want to put on a Brembo 4P caliper. I have a NCY fork.
Re: brake caliper adapter
Posted: Thu Mar 03, 2016 2:10 am
by chainsaw
Posted: Tue Mar 08, 2016 9:46 pm
by MKE PCX
Which Brembo caliper are you going to use?
Are you going to replace the master cylinder as well?
If you have success, I may have to follow in your footsteps.
Posted: Wed Mar 09, 2016 11:39 am
by troy
I think I found a adapter. "Frembo" makes a adapter for Pcx stock fork to use a 4 piston brake, 100mm pitch with 20mm shim for a 260mm brake disk! !!! Still checking if it will work on my NCY front fork.
