				Windshield Removal
				Posted: Sat Mar 19, 2016 6:27 pm
				by jasunday
				I am replacing the stock (short) windshield on my 2015 Forza 300 with the Honda tall windshield and am seeking advice on how to remove what Honda’s instructions refer to as the SCREEN GARNISH – that’s the Y-shaped painted Tupperware that sits below the windshield and between the headlights.
After removing the three screws located between the headlights that secure the SCREEN GARNISH, I tried to remove it with my fingers by pulling the bottom of the SCREEN GARNISH out and down towards the front tire but I was unable to work it free and the two clips in the center of the SCREEN GARNISH remain attached.
Any suggestions or advice would be appreciated.
jasunday, Las Cruces, NM
				Re: Windshield Removal
				Posted: Sat Mar 19, 2016 6:44 pm
				There's instructions
here.
I had a go so I could clean under the screen but found the plastic piece very difficult to remove, so gave up because I thought I was going to break it.
				Posted: Sat Mar 19, 2016 7:04 pm
				by jasunday
				gn2 wrote:There's instructions
here.
				Posted: Sat Mar 19, 2016 9:53 pm
				by davenowherejones
				You have to violently pull on it in the RIGHT direction. Scary. It is a stupid spring loaded pinch point. I did it and it is still scary.
				Posted: Sat Mar 19, 2016 10:34 pm
				by jasunday
				Dave, by RIGHT direction is that to the right or the correct direction. Is down and forward the RIGHT direction. I appreciate your encouraging me.
jasunday
				Posted: Sun Mar 20, 2016 5:42 am
				by phantom309
				when i did mine . ( there is a youtube somewhere but can't find it ).3 screws ..then you go from the top of the panel not the bottom ... 3 / 4 inches down from top put finger tips between screen and body , and slide down ward with the panel an it should pop out of it's clip. then do other side .. the little clips are just above the indicator....at worse case ,i was told sometimes the little yellow clips break,and are replaceable . but the panel is pretty strong ...
				Posted: Sun Mar 20, 2016 5:55 am
				by phantom309
				you can just see the yellow clips that slide onto the lugs...
				Posted: Sun Mar 20, 2016 8:33 am
				I am soon glad the PCX isn't this hard to do. It took me all of 5 minutes to change out our windshield. See, there are advantages to little bikes. :-)
(Sorry, I just had to say that.) If you are afraid to do that, might it be possible to go to the dealer and have their mechanics take it off? Then you can ride home with that part strapped to the back, change your windshield, and then just pop it back on.
				Posted: Sun Mar 20, 2016 9:00 am
				by jasunday
				phantom309 wrote:you can just see the yellow clips that slide onto the lugs...
phantom309
Thanks for the tips.
jasunday
				Posted: Sun Mar 20, 2016 11:31 pm
				by Gordo
				http://youtu.be/uUlLhz5EXDI
Here is the link for the removal of the panel below the windscreen on the Forza 300!
I have had my Forza for 12 months, love it. I have the the complete service manual on my ipad/computer, if anyone needs any info from it let me know and I can email to them.
				Posted: Mon Mar 21, 2016 8:56 am
				by jasunday
				Gordo wrote:http://youtu.be/uUlLhz5EXDI
Gordo,
Thanks for the YouTube link. It was very helpful.
jasunday
				Posted: Sun Jul 17, 2016 6:02 am
				by Mdk1
				Nice find with the YouTube link,
Helped me today fitting my tall screen.
