High pressure radiator cap *found*
Posted: Wed Apr 06, 2016 5:50 pm
by dem0nk1d
Gents,
After doing some cross checking on part numbers the Honda CRF-250R 2013 model uses the same radiator cap as the PCX 150. OEM Honda part# 19037-GEE-710. If you would like to upgrade to a 1.6 BAR High pressure cap you can grab this one here locally in the United States directly from the vendor. I just happened to pick mine up at a local shop had it in stock.
Outlaw Racing High Pressure 1.6 Radiator Cap
Item Code: 12-001
http://store.outlawracingproducts.com/ourahipr16ra.html
Re: High pressure radiator cap *found*
Posted: Wed Apr 06, 2016 8:04 pm
by dem0nk1d
!!CONFIRMED IT FITS!! just got home and installed it!
Posted: Wed Apr 06, 2016 11:06 pm
by RRocket
I have to ask...what's the benefit?
Posted: Wed Apr 06, 2016 11:34 pm
by dem0nk1d
Read up on this post >>> http://www.hondapcx.org/viewtopic.php?f=9&t=4009
Basically helps from overheating the engine. I think the stock one is set to open up at 0.8 BAR
Posted: Thu Apr 07, 2016 12:44 am
by RRocket
Do people really overheat their PCX150s??
Posted: Thu Apr 07, 2016 1:09 am
by iceman
Has the ever been a report of one over-heating?
Posted: Thu Apr 07, 2016 6:25 am
by GeorgeSK
I expect that if you are trying to push the PCX's performance envelope that you very well might run into cooling issues. A big bore kit will generate more heat, and possibly more than the stock cooling system is designed for. Higher pressure might be an issue for other bits of the cooling system, but if the rest of the system can take it, a higher pressure system can run hotter, and so pull more heat away. (higher delta T at the radiator).
Posted: Thu Apr 07, 2016 9:36 am
by homie
iceman wrote:Has the ever been a report of one over-heating?
Yes plenty of reports... He will need that when he installs the bore kit, over heating is big concern with big bore upgrades
Posted: Thu Apr 07, 2016 11:05 am
by dem0nk1d
As of now my pcx is the stock bore, with minor mods. Intake, gutted and shorten exhaust, NCY variator. I do tons of freeway riding. Fastest speed is around 79mph. Registered on GPS. =P
Posted: Fri Apr 08, 2016 11:45 am
by BPT7594
Use a lot of water in the coolant mix. It helps cool the engine down more. if you have a 1.6 bar cap like that you can go full water. I'm waiting for mine to be shipped.
Posted: Fri Apr 08, 2016 11:49 am
by BPT7594
dem0nk1d wrote:Gents,
Item Code: 12-001
I did check, are you sure it's a 1.6? I see it's a 1.1 on pictures online.
I know the old SH150 made in Italia use a 1.1 as I can already get one from my local shop.
Posted: Fri Apr 08, 2016 1:01 pm
by dem0nk1d
Item Code: 12-001
It's a 1.6 as stated, it shows 1.6 in the photo. I'm currently running it now.
