High beam indicator, 2013 PCX150
Posted: Fri Aug 12, 2016 8:45 pm
by ajcatman
This one puzzles me, maybe someone can help. I wanted to upgrade the headlight bulbs in my 2013 PCX150. I ordered Prosense bulbs, same wattage on high and low beams as the stock original. After changing them out the high beam indicator comes on and stays on, I lose the low beams and only have high beams no matter what position I place the switch. I thought I may have shorted the wires but the problem went away after I replaced the Prosense bulbs with the originals. I again tried the Prosense bulbs and the problem came back. I'm stumped.
Any ideas?
Re: High beam indicator, 2013 PCX150
Posted: Fri Aug 12, 2016 8:57 pm
by k2apache6.0
I have the same bulbs without issue, same year PCX too. I can't say I looked at the plugs much, could it be they are reversed or upside down if that's possible
Posted: Fri Aug 12, 2016 9:00 pm
by Ishkabibble
I would really like to know the answer to this one.
Posted: Fri Aug 12, 2016 9:32 pm
by ajcatman
I returned the bulbs to the eBay seller. He was really good about sending me a new set. I'll try them out when our Louisiana weather dries out a bit, hopefully, it was just a bad bulb. The seller has a 2013 PCX and says he has no issues with the Prosense. I'll post my results after the change.
By the way, the Prosense bulbs were much brighter.
Posted: Fri Aug 12, 2016 9:40 pm
by k2apache6.0
ajcatman wrote:I returned the bulbs to the eBay seller. He was really good about sending me a new set. I'll try them out when our Louisiana weather dries out a bit, hopefully, it was just a bad bulb. The seller has a 2013 PCX and says he has no issues with the Prosense. I'll post my results after the change.
I got the same off ebay, probably the same guy in the U.S. comparing one bulb against the other, prosense vs stock, they're much whiter with just a hint of bluishness, very slight, and yes, much brighter. I'm really happy with mine.
Posted: Sat Aug 13, 2016 12:00 am
by honkerman
IT does sound like a short in the bulb itself. Hopefully the new one is not also defective.
Posted: Mon Aug 15, 2016 12:42 pm
by ajcatman
Update: Looks like it was the first set of replacement bulbs. New set is working fine.
Posted: Mon Aug 15, 2016 12:44 pm
by Alibally
ajcatman wrote:Update: Looks like it was the first set of replacement bulbs. New set is working fine.
Good. Are they any better than standard?
Sent from my iPad
Posted: Mon Aug 15, 2016 1:47 pm
by ajcatman
Yes, much brighter, slight blue tint.
Posted: Mon Aug 15, 2016 7:03 pm
by kramnala58
Glad to hear it worked out. Bummer that you had to go through the hassle to find out it was a faulty bulb.
Sent from my iPhone using Tapatalk
Posted: Fri Aug 19, 2016 8:17 am
by PCX_Erik
I've had the same issue. I have a 125 PCX. It could be the way you mounted the bulb in the socket. Instead of plugging it in the socket straight in, it goes in at a right angle. Look on the bulb and there should be a little groove. That mounts to the plug where the tab is. I apologize if my answer doesn't make sense. LOL. I havent slept all night.
