seat spring assembly off, anyone got a photo?
Posted: Sat Sep 10, 2016 6:29 pm
by old guy
In error I took off the assembly that contains 2 flat springs that hold up the seat on my 2016. (I was removing the seat and should have left it alone). Now I am not sure how the flat springs fit in the holder and since I don't want to break anything does anyone have a close up photo showing how it fits?
thanks
old guy
Re: seat spring assembly off, anyone got a photo?
Posted: Sat Sep 10, 2016 7:43 pm
by kramnala58
Welcome to hondapcx.org. There is lots to learn here. I have a 2010, so I am not much help with a pic, but hopefully one of our members with a newer model will catch your post and be able to help you out real soon.
Posted: Sat Sep 10, 2016 8:04 pm
by old guy
I think that Honda added springs in the 2015 model year
Posted: Sat Sep 10, 2016 8:48 pm
by homie
Posted: Sat Sep 10, 2016 8:52 pm
Uh oh...Perhaps this illustration will help. Perhaps it's easier to purchase the assembly? My scoot is a '15 I'm not familiar with the "flat springs" that you're referring to. I switched out my seat and don't recall seeing them.
http://www.cheapcycleparts.com/oemparts ... b618e/seat
Not sure old guy where you're located. The parts link above is U S. based. Do us and yourself a favor by completing your profile. Below my post are easy directions to get that done. Thanks and Welcome to our forums :P
Ah...I see homie's here to help. Gotcha covered ;)
Posted: Sat Sep 10, 2016 9:02 pm
by homie
Not sure why the exploded views for both years 15 & 16 are not more detailed. There might be a second flat spring under the one in the video but it would follow the contour most likely still giving you a clue about proper assembly. I took my seat off at the 4 taps like WN and haven't ventured into the area of the detent yet.
Posted: Sun Sep 11, 2016 12:05 am
by old guy
Your video and verbal description are very clear. Its late (British Columbia on the eastern edge of the Pacific time zone) or I would try assembling it tonight. I don't think I will have any trouble now.
Thanks for the help.
The reason I had the seat off was to attach velcro strips under a small portion of the lip of the seat which in turn attach to velcro I sewed on to an automotive type gel seat pad. I could have just sat on it but I decided to attach it instead. In my opinion the stock seat uncomfortable for long trips and this is a low cost cure. Just luck but a gel and mesh automotive seat pad ($20. at Canadian Tire) fits almost perfectly and other than adding about an inch to the seat height there seem to be no issues. I take it off for around town.
If anyone else takes long rides it is well worth it.
Posted: Sun Sep 11, 2016 10:48 am
Location? Please add that to Your Profile old guy :)
Thx, WN
Posted: Sun Sep 11, 2016 1:45 pm
I have a gel seat pad on my 2013 and I used a ROK strap to hold it on. So far it is holding quite nicely.
Posted: Sun Sep 11, 2016 1:57 pm
by homie
We had a Canadian Tire but it moved to Canada :
Go full screen and if that still isn't enough detail I could back out those screws and take a better look.
https://www.youtube.com/watch?v=2cPPSgXDsWI
