How much can the PCX take
Posted: Fri Oct 21, 2016 10:33 am
by chet
I have a 2013 PCX 150, there are times i make a 15-18 mile run on the interstates and thats is flat out bouncing off the rev limiter, maybe twice a week, for sure once, i keep it serviced ect, bike has 7500 miles on it now, will this kind of riding hurt it's engine life, would this be considered hard riding
Chet
Re: How much can the PCX take
Posted: Fri Oct 21, 2016 11:14 am
by kramnala58
If wide open was your all the time riding speed, it might be a concern, but a couple of times a week as a part of a larger percentage of other riding shouldn't be an issue.
Posted: Fri Oct 21, 2016 3:04 pm
by ScooteringAbout
Nearing 9000 miles on mine, engine seems sweet as a nut and it has this twice every day I take it out:
https://www.youtube.com/watch?v=QeYjk3iMthQ
Posted: Fri Oct 21, 2016 3:34 pm
chet wrote:I have a 2013 PCX 150, there are times i make a 15-18 mile run on the interstates and thats is flat out bouncing off the rev limiter, maybe twice a week, for sure once, i keep it serviced ect, bike has 7500 miles on it now, will this kind of riding hurt it's engine life, would this be considered hard riding
Chet
How many miles are you planning to keep the bike for?
Posted: Fri Oct 21, 2016 3:50 pm
by honkerman
I got my PCX toward the end of the summer last year. It has 11,000+ miles on it. For about nine months, I used it much the way you do, once or twice a week on 55+ mph roads. When I went to assess the driven pulley bearing, i observed that the faces on the drive pulley had become pretty well grooved from the heavy high speed riding. This is why I swapped out the variator for an NCY racing variator.
The engine itself seems none the worse for wear, but my hard use did take a toll on the transmission. Easy enough to fix though.
Posted: Fri Oct 21, 2016 7:51 pm
by riding@100mpg
That's what the rev limiter does, shuts the engine down before any trouble occurs. Don't worry about it
Posted: Fri Oct 21, 2016 7:53 pm
by kramnala58
Smooth ride Drew. I noted that your max speed was about 63-64 mph (due to traffic) and it didn't sound like the motor was straining. What has your top speed been?
Posted: Sat Oct 22, 2016 6:17 am
by JetPilot
Chet
Hi Chet,
That depends, HIGH QUALITY oil and keeping the oil changed will be CRITICAL if you want the engine to last with this kind of use. Honda knows a 150 sized engine will be run at wide open throttle much of the time, that small engine is designed exactly for that. BUT, doing this long term depends very much on you.
1. Use a good quality synthetic oil, and keep it changed.
2. Do not go to wide open throttle until engine is warmed up, doing this cold is very bad and will wear the engine a lot over time.
Mike
Posted: Sat Oct 22, 2016 9:31 am
by chet
you you wrote:chet wrote:I have a 2013 PCX 150, there are times i make a 15-18 mile run on the interstates and thats is flat out bouncing off the rev limiter, maybe twice a week, for sure once, i keep it serviced ect, bike has 7500 miles on it now, will this kind of riding hurt it's engine life, would this be considered hard riding
Chet
i average 3500 miles a season, so i am hoping at least 4 YRS
Posted: Sat Oct 22, 2016 9:36 am
by chet
honkerman wrote:I got my PCX toward the end of the summer last year. It has 11,000+ miles on it. For about nine months, I used it much the way you do, once or twice a week on 55+ mph roads. When I went to assess the driven pulley bearing, i observed that the faces on the drive pulley had become pretty well grooved from the heavy high speed riding. This is why I swapped out the variator for an NCY racing variator.
hi Paul
I never took off the drive cover, guess i should and see if my drive pulleys faces are worn, , so i see you use the so called NYC Variator, i am going to google that and check it out. i will be ordering new tires shortly and maybe i will see what i need to complete the drive set up
Chet
Posted: Sat Oct 22, 2016 1:17 pm
by ScooteringAbout
I've had the needle at close to 70mph before I've backed off, not yet hit the limiter.
Posted: Sat Oct 22, 2016 3:59 pm
chet wrote:you you wrote:chet wrote:I have a 2013 PCX 150, there are times i make a 15-18 mile run on the interstates and thats is flat out bouncing off the rev limiter, maybe twice a week, for sure once, i keep it serviced ect, bike has 7500 miles on it now, will this kind of riding hurt it's engine life, would this be considered hard riding
Chet
Then you have absolutely nothing to worry about.
Posted: Sun Oct 23, 2016 6:21 am
by JetPilot
That was my thought exactly, you would have to have a lot of help, downhill or some major drafting to actually hit the limiter. The original poster may be running wide open most of the time, but I seriously doubt he would hit the limiter often with a stock scooter. The PCX runs out of power before it reaches its RPM limit at high speeds...
Mike
