2016 pcx 150 break mpg
Posted: Sat Dec 03, 2016 3:50 pm
by Mike888
Hi, I was wondering is it normal for mpg to be around 59. The pcx currently has 20 miles exact. Is mpg higher during break in or lower. Also what is the max speed I can go during break in. Thanks in advance
Re: 2016 pcx 150 break mpg
Posted: Sat Dec 03, 2016 5:30 pm
by honkerman
Judging your mpg at only 20 miles in is not going to be accurate.
Just the same, the first tank on a scooter usually gives lower than normal mpg.
Don't panic just yet.
Posted: Sat Dec 03, 2016 7:14 pm
by doletotodole
REALLY DRUNKENS ME WORRYING ABOUT MPG AT 20 MILEAGE...
Posted: Sat Dec 03, 2016 9:27 pm
by Mike888
Oh ok, what is the max speed do you guys recommend me going. Also is starting half throttle consider bad when break in and adding mor egas to increase speed.
Posted: Sat Dec 03, 2016 9:38 pm
by honkerman
Mike888 wrote:Oh ok, what is the max speed do you guys recommend me going. Also is starting half throttle consider bad when break in and adding mor egas to increase speed.
There is an ongoing civil war in the motorcycling community over how best to break in a new bike. On the one side, you have those who say ride it hard, and on the other there are those who say take it easy. For myself, I go the middle road.
During the 300 mile break-in of my own PCX, I rode it to its max if I needed to, but would roll on and off the throttle at higher speeds. My PCX turned out just fine.
Posted: Sun Dec 04, 2016 7:33 am
by easyrider
Mix RPM'S- nothing steady for a long time. Keep RPM varied. Short duration run ups only. Do not idle long periods
Posted: Sun Dec 04, 2016 8:10 am
Mike888 wrote:Hi, I was wondering is it normal for mpg to be around 59. The pcx currently has 20 miles exact. Is mpg higher during break in or lower. Also what is the max speed I can go during break in. Thanks in advance
Has anybody seen my will to live, I've mislaid it.
Posted: Sun Dec 04, 2016 10:46 am
No, never seen it! Probably won't either
Posted: Sun Dec 04, 2016 5:03 pm
by JohnL
[/quote]
Has anybody seen my will to live, I've mislaid it.[/quote]
Found it, added it to my own, you can make your own arrangements now :D :D :D
Posted: Mon Dec 05, 2016 3:13 am
Found it, added it to my own, you can make your own arrangements now :D :D :D[/quote]
Have you got mikes owners manual too?
