New PCX Acceleration Noise
Posted: Sun Dec 04, 2016 6:44 pm
by doletotodole
I just got my 2016 PCX last night...
Everything feels good except when I speed up where I can hear the rattling noise from engine.
After reaching around 50-60 km/h, the rattling seems to disappear and the entire scooter sounds very smoothe...
Is it normal for PCX, do you guys have the similar experience?
Thanks.
Re: New PCX Acceleration Noise
Posted: Sun Dec 04, 2016 7:29 pm
by homie
If I recall over my membership time I've seen a few low severity rattles diagnosed in here as the following, and perhaps others can recall more possibilities.
Deceleration on a PCX makes a lot of vibration, so much so you can't mount a camera to the body.
1. Check the license plate. I placed wool fiber spacers between the plate and the mount to insure certain rpm's didn't start it vibrating.
2. There is a close connection up front between the stock windscreen and the body panel, (at the nose) put a buffer between these two items and ride out eliminating the easy fixes first.
Posted: Sun Dec 04, 2016 9:25 pm
by iceman
Are you sure it's coming from the engine? You say it's across the range of normal commuting speeds (upto 50-60kmh) - I'd take it back to the dealers as it should not be like that from new.
Posted: Sun Dec 04, 2016 9:37 pm
by Mike888
my 2016 pcx150 makes the same noise. There seems to be a rattle at certain speeds. Is yours similar, it sounds like its a rod knock
Posted: Sun Dec 04, 2016 9:43 pm
by Jge64
It normal in the midrange..... it's a single cylinder, therefore there's always going to be some noise vibration and harshness (NVH).
Posted: Mon Dec 05, 2016 8:37 am
by doletotodole
doletotodole wrote:I just got my 2016 PCX last night...
Thanks.
Sir, the noise is not about front screen or back plate, sounds like from water tank or engine compartment... after all, I only rided for 8km...
Posted: Mon Dec 05, 2016 8:40 am
by easyrider
I think you will find such noises to be normal for this animal..
Posted: Mon Dec 05, 2016 8:42 am
by doletotodole
easyrider wrote:I think you will find such noises to be normal for this animal..
Thank you.
Posted: Mon Dec 05, 2016 8:43 am
by doletotodole
Mike888 wrote:my 2016 pcx150 makes the same noise. There seems to be a rattle at certain speeds. Is yours similar, it sounds like its a rod knock
Absolutely, Mike, it is the knocking sound as you described, which is more precise than rattling... it happens when I accelerate from 30-60km/h.
Just hope it will go away after break in, apart from this, PCX is great.
