125 ESP differences
125 ESP differences
On the general theme of the bike differences... took my 125 ESP exhaust off to clean it and offered a new non esp gasket up. Much too small. Another different part.
Re: 125 ESP differences
I believe that the engine is completely different.
PCX 125 CANDY RED
Color: RED
Post by PCX 125 CANDY RED »
What about variator ? Very important- does variator from 2012 model fit and work smoothly on the esp model ????
Smile - it's easy =)
Look at the.part number.
PCX 125 CANDY RED
Color: RED
I have no idea if all of the questions got answered. I have read this thread and gone to the link, and I am as confused as ever. First, on the belts, how can we tell which one is correct if there are multiple numbers for the same belt? The only way that I can be sure when I replace mine i to go to the Honda dealer and ask them to look up the correct one, and order it. I had to wait for it to arrive since it wasn't in stock.
Next, the variator. I have a 2013 Esp 150 and want to install an NCY variator and drive face. The one I have seen advertised, says it is for 125 and 150. It does not say for Esp or not. Sooooo....the question remains...are the variators for Esp the same as for non-Esp?
Pcxdemon
Post by Pcxdemon »
Hey mel, yes variators are interchangeable but weights are set different for each model. There are 3 diff belt sizes, first gen 125 ( non esp) has the shortest belt, 125 esp has slightly longer belt and first gen 150 esp has the longest. Newest or latest model Pcx 150 has gone back down to 125 esp model belt size. I'm using esp model designated variator on my first gen Pcx in combination with esp 125 belt and have no issues, works really well..
Hope that helps instead look at part number thingy advice...
Pcxdemon
Post by Pcxdemon »
gn2 wrote:I believe that the engine is completely different.
From experience and actual know no not really..
Commenting on facts, or just criticising me generally?
PCX 125 CANDY RED
Color: RED
Ok
But http://makinaparts.com says this
THATS makes me CRAZY !!!!
PCX 125 CANDY RED
Color: RED
OMG !
http://www.ebay.ie/itm/PCX-125-VARIATOR ... 2801898852
Seller information
mikeqwerty (383 Feedback score: 383)
99,1% Positive Feedback
Next
PCX 125 VARIATOR PRIMERY DRIVE FACE, PULLY,SET,ROLLERS, :geek: :geek: :geek: 09-14 :geek: :geek: :geek: HONDA GENUINE OE
HONDA MOTOR CO.,LTD
GENUINE OE FACTORY STANDARD FITMENT
VARIATOR PULLEY DRIVE FACE SET
(drive face x 1 - face comp movable drive x 1 - plate ramp x 1 - roller set 6 weight x 1 - slide 3 set x 1 - boss drive face x 1)
PCX 125 ALL YEARS 2009- 2014
''original standard factory part''
(we recommend item installed by a experienced person) £55.99 PRIORITY AIR MAIL.
TRACKING NUMBER.REGISTERED DELIVERY
ITEMS WILL BE DISPATCHED WITHIN 2 WORKING DAYS OF PAYMENT BY AIR MAIL.MOST ITEMS ARE RECEIVED IN 4 TO 7 DAYS OF DISPATCH.SOME ITEMS MAY TAKE A LITTLE LONGER DUE TO THE POSTAL SYSTEM OF YOUR COUNTRY...IF YOU HAVE ANY QUESTIONS PLEASE CONTACT ME.
I ALSO HAVE STOCK OF OTHER PARTS FOR PCX THAT ARE NOT LISTED YET.
PLEASE MESSAGE ME IF YOU NEED A PRICE FOR OTHER PARTS.I WILL GET BACK TO YOU AS SOON AS I CAN.
POSTAGE ; IF YOUR ITEM DOES NOT ARRIVE IN 21 DAYS PLEASE CONTACT ME.
YOUR PURCHASE IS PROTECTED BY Ebay REGULATIONS (refund or replacement will be sent)
Brand: Genuine OE (Original Equipment)
To Fit Model: PCX 125CC
Manufacturer Part Number:
22102-KWN-900...22110-KWN-901...22110-KWN-901
Other Part Number: 22123-KWN-900...22011-KWN-900...22105-KWN-900
VARIATOR DRIVE FACE SET
Pcxdemon
Post by Pcxdemon »
The only thing that's really different between models is the belt lengths and weight set per model ie 150 uses 15 or 18g depending of the belt size for the year of build, all else is the much the same.
PCX 125 CANDY RED
Color: RED
Dear best-buyer,
Hi I have checked the parts catalog for pcx 125 from 2009 to 2014.
Also pcx 150 from 2012 to 2014 and they are the same part number/model number and batch number.. 19 grams per weight 20mm x 15mm . 22123-KWN-900
The pcx range share a lot of the same components,some components have been revised but will still fit early models.
I use a pcx 150 2012 model but use the 2015 weights ...22123-K36-TOO the same part number different model number and batch number because they are 15 grams each . The first number is the part number- the second reference to model-then batch.
Parts are revised all the time the first numbers are unique to a particular part.
There are a lot of models that share the same parts,its like lots of different bikes share the same tire's and there can be many different brands to fit the same bike.
I always try to cross reference as much as possible.
Than you
Mike
PCX 125 CANDY RED
Color: RED
Hello ! I'm still having trouble with my belt ! So tired
Please help
PCX 125 CANDY RED
Color: RED
23100KWN711 ( is my GENUINE on the EsP PCX 125 (came from Japan) )
23100KWN711 1000% shorter than 23100KZR601
ORDERED 3 bekts from factory HONDA in THAI - to big for my PCX 125 ESP 2013
I dont know where to buy 23100KWN711, please advice.
23100KWN711 So FKn rare and expensive belt
