Engine Problem
Posted: Sat Apr 08, 2017 2:16 pm
by Fatal0007
Since the beginning of the year my engine cuts out every time I come to a complete stop. It starts up right away as long as I accelerate when I start and only cuts out again if I let go of the throttle. I bought the bike brand new In July and it started having this problem around 9000 miles. I've had it checked multiple times from a scooter repair shop that I regulatory go and they've called Honda every time and neither one know whats wrong with it.
Re: Engine Problem
Posted: Sat Apr 08, 2017 4:08 pm
by easyrider
Cmon man, that's an easy fix, and Honda cant figure it out.??? What do you mean they cant figure it out.. What parts did they change or diagnosis was postulated. They must have said something or tried something .
Re: Engine Problem
Posted: Sat Apr 08, 2017 7:10 pm
by MayHem
Maybe turn the start stop feature off, located on the right side of handlebar haha. Is this a joke?
Re: Engine Problem
Posted: Sun Apr 09, 2017 5:12 am
by kramnala58
MayHem wrote:Maybe turn the start stop feature off, located on the right side of handlebar haha. Is this a joke?
Fatal0007 wrote:Since the beginning of the year my engine cuts out every time I come to a complete stop. It starts up right away as long as I accelerate when I start and only cuts out again if I let go of the throttle. I bought the bike brand new In July and it started having this problem around 9000 miles. I've had it checked multiple times from a scooter repair shop that I regulatory go and they've called Honda every time and neither one know whats wrong with it.
But that would depend on where you are from as this is not a feature on North American PCX's. It helps us to help you better if you include your location as a part of your profile. You can access your profile settings through the 'User Control Panel' at the top left of the web page.
Re: Engine Problem
Posted: Sun Apr 09, 2017 7:47 pm
by AustinPCX
My Forza did the exact same thing right after I changed the spark plug. Adjusted the gap closer to the lower tolerance of .80mm and problem solved.
Re: Engine Problem
Posted: Mon Apr 10, 2017 7:05 am
by fish
Slip in an Iridium spark plug , see if that helps. $8, nothing to lose.
