Engine making ticking noise after Valve adjustment
Posted: Sun Dec 02, 2012 6:56 am
by pcxtourer
Hi Guys,
I'm new here and would like to get into the community more. I'm only just getting back onto my pcx now, I brought it at the start of 2011 but about a year ago burnt the piston (Long Story), the engine was bored and rebuilt but it had trouble at idle and kept stalling. I have just done a valve adjustment today and it finally works like usual; Starts up instantly and doesn't choke and stall at idle but now a loud ticking noise has popped up. The Intakte valve was sitting at 2.5mm out, The setting is 0.10mm! Exhaust valve hadn't moved and was in spec 0.25mm.
The noise wasn't there before the valve adjustment and was wondering if anyone could help me with what it may be! I have uploaded a video to youtube of the problem (
http://www.youtube.com/watch?v=a0fyvfLF ... e=youtu.be)
Any help would be greatly appreciated! I love the pcx, can't wait for it to be going smoothly again!
Thankyou,
Giuseppe
Re: Engine making ticking noise after Valve adjustment
Posted: Sun Dec 02, 2012 7:37 am
pcxtourer wrote:about a year ago burnt the piston (Long Story)
Tell us more, sounds interesting.
Posted: Sun Dec 02, 2012 10:00 am
by PCX-rider
Are U homemade mechanic or trained mechanic?
Posted: Sun Dec 02, 2012 10:55 am
by Mitch Detailed
Sounds like its time for another rebuild if you ask me. You have to set valve lash at top dead center, tdc for short. If your engine isn't at tdc and you try to set valve lash, you could set the lash incorrectly, causing lack of power, bent valves, cracked piston, trashed valve seats, etc.
More damage is done if you adjust too tight than too loose. You typically need. .045" between the valves, and the valve and piston.
Good luck.
Posted: Fri Dec 07, 2012 5:21 am
R-check your clearances before you do anything else. My guess is that you'll find that they aren't what you think they are.
Posted: Mon Apr 14, 2014 9:00 pm
by dem0nk1d
pcxtourer wrote:Hi Guys,
Thankyou,
Giuseppe
Giusepee,
Any updates? I did my valve adjustment today and having the same horrible sounds. Tripled checked my work, questionable about the TDC marks on the cam using the dimple. I have a few - | marks, and two dimples, and one painted area...
Posted: Mon Apr 14, 2014 10:33 pm
by dem0nk1d
update on myside the cam was 180 off. So this was probably the same issue you had.
Posted: Tue Apr 15, 2014 10:52 pm
by stryder123
Pull the spark plug. As you turn the motor over slowly feel inside for when the piston is at top then you can check where your marks are at on the cam.
Posted: Wed Apr 16, 2014 9:15 am
by dem0nk1d
here are my finds for the backside of the 150 cam.
