125/150 parts compatibility and interchageability
Posted: Tue Dec 11, 2012 6:00 pm
by cessna151
When i first bought my PCX150 i had no idea how it was different than the 125 other than the engine and many distributors still don't list parts for the 150. With some help on the other forum i have organized a short list of parts according to whether or not they can be used on both the 125 and the 150.
I will continue to add to this list as reports come in.
INTERCHANGEABLE
Variator (However, stock variators may vary slightly between the two)
Seat
Windshield
Wheels/tires
NOT INTERCHANGEABLE
Air filter/air cover
Radiator/radiator cover
Exhaust/header
Re: 125/150 parts compatibility and interchageability
Posted: Tue Dec 11, 2012 6:01 pm
by cessna151
Can anyone verify that all the plastic body work is the same on both?
Posted: Tue Dec 11, 2012 6:37 pm
by Mitch Detailed
Some plastics are, some aren't. The physical mounting points are the difference. Look up the frame between the 125/150 and you'll see they completely redesigned the frame system
Posted: Wed Dec 12, 2012 3:48 am
cessna151 wrote:Can anyone verify that all the plastic body work is the same on both?
Apart from the fuel flap panels it does seem to be the same
Posted: Wed Dec 12, 2012 9:10 am
by cessna151
If that's the case i think it would be a good idea to sort out which ones are or aren't.
On a side note, why can't i edit my OP?
Posted: Wed Dec 12, 2012 10:42 am
Mitch Detailed wrote:Some plastics are, some aren't. The physical mounting points are the difference. Look up the frame between the 125/150 and you'll see they completely redesigned the frame system
So which are and which aren't?
Posted: Wed Dec 12, 2012 12:52 pm
by Mitch Detailed
I don't know off the top of my head. The midsection is where it gets tricky. The bike is .6 inches longer wheelbase. And there's a spark plug access panel not present on the 150s.
Posted: Wed Dec 12, 2012 4:32 pm
There's no spark plug panel on the 150s? I've got an ESP 125 and just assumed it was a sleeved down 150, but its got the sparkplug access hatch
Posted: Wed Dec 12, 2012 5:03 pm
by Mitch Detailed
Look at illustrated parts diagrams on sites, you'll see ;)
Posted: Wed Dec 12, 2012 5:20 pm
Life is too short, I'll take your word for it :)
Posted: Thu Dec 13, 2012 9:58 am
by cessna151
I have the 150 service manual. Perhaps if somebody has a 125 service manual we could compare pictures to determine which are different.
Posted: Thu Dec 13, 2012 3:53 pm
by maddiedog
cessna151 wrote:On a side note, why can't i edit my OP?
Forum rule -- it prevents bait and switch, and keeps everyone honest.
Send me a PM or reply if you want the OP updated, and I'd gladly update it for you. :)
