lights
Posted: Wed May 02, 2018 9:40 am
by pcx150blue
Hello,
I 'am not sure if this where I should ask this. I have a 2018 with less than 100 miles . I noticed when it is idling the dash flickers along with the lights as soon as it is revved up it is ok . I don't know if this is normal or not. I wouldn't think there would be a problem on a scooter this new .
Re: lights
Posted: Wed May 02, 2018 9:51 am
This is only a guess, but back in the old days the motorcycle did not have a battery and instead used a magneto. When the bike idled the lights would flicker. The PCX doesn't have a magneto but could be wired in such a way that the starter, which is also the alternator, handles the lights, in which case the lights would flicker while it idles.
Re: lights
Posted: Wed May 02, 2018 10:02 am
The lights should never flicker, if its still under warranty take it back and have them sort it.
Re: lights
Posted: Wed May 02, 2018 1:30 pm
Mine have always flicked when first started. Then they settle down to constant, almost as though there were a capacitor inline that needed to be charged up.
I probably has nothing to do with your bike, but I also have a Honda lawn mower with an electric starter. It has to be pulled the first time because it IS charging a capacitor. Capacitors bleed out after awhile of non-use, so I have to pull start it one time each time I cut the grass. That is what made me thing that maybe the bike is the same way. If it has LED lights it does not need that extra circuit. I just noticed that yours is an LED model, so I would take it to the shop and ask them.
Re: lights
Posted: Thu May 03, 2018 4:33 am
by iceman
As GN2 stated, no way LED lights on a recent model of PCX nor the dash should flicker when started or any time when riding - either the battery is faulty or there is some electrical fault. The dealer should sort this or write to Honda and complain if no joy from the dealer.
Re: lights
Posted: Thu May 03, 2018 7:05 am
by pcx150blue
Thank You for the response. I think I might have panicked a little bit. I took it out for about a 10 mile ride after that everything seems ok now. maybe it just needed to be ran .
Re: lights
Posted: Sun May 06, 2018 2:59 am
by Gil
It could also be that the battery was a little low. I also notice that my dash lights flicker when I start the bike.
I think you are ok.
Gil
