Do I have to use MB oil?
Posted: Fri Jun 29, 2018 2:29 am
by slowpoke
Cycle shop only sells Honda 10W-30 MA oil for wet clutch motorcycles. The manual says to use MB since, I'm assuming, the Forza has a dry clutch. Does it make a difference and can I also just use full synthetic Mobil 1 10W-30 automobile oil? This will be my first oil change after the 600 mile break-in.
Re: Do I have to use MB oil?
Posted: Fri Jun 29, 2018 4:01 am
Doesn't need to be MB but at 600 miles better so steer clear of fully synthetic imo.
Posted: Fri Jun 29, 2018 7:50 am
by Jge64
Starting with my 600 mile change i switched to mbil 1 synthethic. I change every 9 mo or so. No prob for the last 3 years....
Posted: Fri Jun 29, 2018 7:54 am
by k2apache6.0
Better to fully break the engine in on regular oil, you might be ok at 600 miles though. Personally I do 1k on regular oil then a full synthetic thereafter.
Posted: Fri Jun 29, 2018 8:02 am
by 87112
Well the manual states to not use any oil for the Forza that has energy or resource conserving label on the back of the bottle.
Some posters have stated thats not true, you can use it since Forza has a dry clutch. But someone else said Honda manual is correct.
I don't know, I know I can't feel good going against the manual and will use Cheap Chevron 10W-40 dino oil next change which has not resource or energy conserving on the back.
Posted: Fri Jun 29, 2018 9:29 am
So long as the oil is slippery you'll be fine.
Sticky oil is no good.
Posted: Fri Jun 29, 2018 9:39 am
by aguim
Honda manuals are written by lawyers who, bright as they are, mostly copy anything they can get their
hands on, hence some bizarre, irrelevant 'warnings'.
I have used car energy conserving oil many times in the Forza, no problem. Any good oil that comes
cheap on a given day will be just fine (to date, 30K, I think I must have used all available brands/
viscosities available around here, engine doesn't give a damn).
Posted: Fri Jun 29, 2018 10:18 am
by SteveP
slowpoke wrote:Cycle shop only sells Honda 10W-30 MA oil for wet clutch motorcycles. The manual says to use MB since, I'm assuming, the Forza has a dry clutch. Does it make a difference and can I also just use full synthetic Mobil 1 10W-30 automobile oil? This will be my first oil change after the 600 mile break-in.
The service manual recommends Honda Pro HP4M 4 stroke oil...this has molybdenum additives in it, which add "slipperiness" to the oil. Use it if possible...Honda must have some reason for recommending it over their oils without molybdenum.
The service manual also adds to the above recommendation "....or equivalent motorcycle oil, API service classification: SG (owners manual says SJ) or higher, except oils labeled as energy conserving on the circular API service label), JASO T903 standard: MB, SAE 10w30.
If the dealer doesn't have the HP4M oil, they can order it...I don't think there's much difference in price. Sadly, motorcycle dealers don't seem to always be familiar with scooters!
Posted: Fri Jun 29, 2018 11:02 am
by davenowherejones
I have never seen HP4M 10W30 anywhere locally. Like Agium says any oil will do. I have 77653 km on my very early production Forza and I use the factory 12,000 km oil change interval.
Posted: Fri Jun 29, 2018 11:26 am
by aguim
Dave, you're the livin' and kickin' proof that I'm an oil-change maniac (2,000 km vs 12.000).
OK, take yours apart @ 100.000 km and show us the innards, will you...
Posted: Fri Jun 29, 2018 12:38 pm
by slowpoke
Appreciate all the answers. I bought the Forza new (2014 model sitting at the dealership for several years), and I believe it came with regular oil. So after the initial 600 mile interval, I'll change it to full synthetic, right? The dealer said they didn't carry the MB oil because nobody around here rides scooters (hence why they sold the Forza below cost ), but they'd order some cases for me.
Posted: Fri Jun 29, 2018 12:47 pm
Bad practice to use fully synthetic until its done around 4000 miles.
Posted: Fri Jun 29, 2018 1:16 pm
It's the silly season, someone mention Bob the Oil Guy. :lol:
Posted: Fri Jun 29, 2018 1:54 pm
by easyrider
The old adage that synthetics are too slippery to add to a new engine is BS.The factory fill has the proper amount of friction modifiers necessary to seat the rings.After 600 add whatever you like,Honda had already took that into consideration.
Posted: Fri Jun 29, 2018 5:21 pm
easyrider wrote:The old adage that synthetics are too slippery to add to a new engine is BS.The factory fill has the proper amount of friction modifiers necessary to seat the rings.After 600 add whatever you like,Honda had already took that into consideration.
x2. It's one step up from a lawn mower engine in terms of routine servicing. Let's not over think things or gild the lilly
Posted: Fri Jun 29, 2018 5:50 pm
by JohnL
Haven't had my Honda mower serviced for over five years, but regularly change the oil on my PCX. I guess that says something about my priorities. :lol: :lol:
Posted: Sat Jun 30, 2018 5:27 pm
by superandyp
I save the good stuff for celebration and drink the blended for breakfast. Hmm silly season.... Is the sensible season when we are freezing our nuts off :lol:
Posted: Sat Jun 30, 2018 7:14 pm
by springer1
JohnL wrote:Haven't had my Honda mower serviced for over five years, but regularly change the oil on my PCX. I guess that says something about my priorities. :lol: :lol:
Maybe consider changing the oil in that mower.
Posted: Sat Jun 30, 2018 7:55 pm
by JohnL
My wife has a battery electric mower, if I don't use the Honda mower she does the mowing. Doesn't say a lot about my morals, but at least the grass gets cut. :lol: :lol:
Actually she loves mowing :D :D
