Does the 2015/16 Forza 300 utilise ACG (PCX start-system)?
Posted: Mon Jul 16, 2018 9:23 pm
by erisaman
I understand the ACG system as standard in the PCX - but does the Forza NSS300 (pre-2018) utilise the same combined starter and alternator system? Specs state that the Forza has a "self-starter' but also states that "ACG output is 380 watt"?
Re: Does the 2015/16 Forza 300 utilise ACG (PCX start-system
Posted: Mon Jul 16, 2018 11:09 pm
I believe the original model Forza introduced in 2013 has a separate starter and alternator, it definitely does not have idle stop.
The new facelifted one might do.
Posted: Tue Jul 17, 2018 12:43 am
by erisaman
Thank you for that - I posted early morning but thought I'd check to see if our overseas cousins had posted a response... but no, you are up to it before 'the ink has dried'. Thank you again - there will be many more questions to follow no doubt.
Posted: Tue Jul 17, 2018 2:51 am
Early shift this week, start work at 06.30 so up at crack of sparrows.
