Pcx 2019 topbox fitting
Posted: Wed Aug 15, 2018 11:01 am
by marc1973
Hello there guys i have a question can you use giviSR1136 brackets on the 2019 model as i want to fit a givi topbox
Re: Pcx 2019 topbox fitting
Posted: Sat Aug 18, 2018 12:30 pm
I haven't found anything concerning them fitting a 2019 version specifically, but that is probably because the 2019 model is just being introduced. My suggestion would be to try it. You should be able to hand tighten the bolts that come with the kit, so if the holes line up and you have no problem screwing in the bolts, then I would say that it fits.
I have noticed that descriptions vary as to the Year-models it will fit. The reason for that is probably because the websites have not updated their descriptions for quite some time. I did find one site that stated that the kit would fit models from 2010 to current.
