Dragging
jojo87
Year: 2015 Honda MSX
Dragging
Post by jojo87 »
Hey,
A bit weird,
went out about an hour ago for a ride,
obviously pulled the throttle back to go,
and when letting go you gradually slow down...
but for some reason my Bike feels like its dragging back,
not sure how else to explain,
as soon as I let go of the throttle... there was a sudden speed difference and I shuddered forward a bit,
I carried on riding and was noticing it more,
what could be causing this?
Mgalutia88
Year: 2013 PCX 150
Re: Dragging
Post by Mgalutia88 »
Your on a scooter and the clutch is engauged until you get below 10mph. This means its the same as being in a manual transmission car in say first gear at 5000-6000 rpm and letting off the gas while leaving it in gear. The same thing will happen. Does that make any sense? We call it engine braking. Truck drivers do this too. Also the same as being in a manual transmission vehicle and downshifting to slow down instead of using the brakes.
jojo87
Re: Dragging
Post by jojo87 »
But it's never happened before...
Re: Dragging
These little pcx scooters have beautiful engine braking. Your brakes last longer and it helps in traffic when you are in stop and go close quarters.Many scooters have it. My Burgman had it. However, the pcx seems to have a greater ability than most other scooters when it comes to engine braking.
jojo87
Re: Dragging
Post by jojo87 »
How come i've never experienced it before when having the Bike for 2 months now? and doing about 1600 miles in those 2 months....?
Alibally
Re: Dragging
Post by Alibally »
Check for a dragging brake. Make sure the wheels spin ok when the engine is off.
Mgalutia88
Year: 2013 PCX 150
Re: Dragging
I think most of us have left the parking brake on at least once. Could that be it?
Mgalutia88
Year: 2013 PCX 150
Re: Dragging
Also my dealer seems to adjust my rear brake too tight for my liking. Has it been recently serviced?
jojo87
Re: Dragging
Post by jojo87 »
Nope, was serviced the first time at 1500 by the previous owner, he left it late!
i've had it about 2 months now, done about 1600 miles..
i've changed the Air Filter and Spark Plug myself,
just changed the Engine Oil yesterday....
Pads on the front look fine,
Drum one looks fine...
was a little odd as, again, it hadn't happened before.
Duggle
Year: 2013 - 150
Re: Dragging
Post by Duggle »
I guess it really depends on how much it is dragging. The PCX is supposed to slow when you let off the gas. It is the first thing that I noticed when I bought mine new and left the dealership. I took off down the road and when I let off the gas (all the way) it really slows itself down with engine braking, much more than I expected. Took a while to get used to that. It's like if you got up into high rpms in 3rd gear or so on a motorcycle and let off the gas (without pulling on the clutch) and downshift on the way down to stopping.
If you are saying that yours was just coasting with zero engine braking before (as if you pulled on the clutch in the example before and coasted freely) then your scooter wasn't working correctly and is operating the way it should now. You should feel that engine braking as the scooter slows down to about 10 mph then you'll notice below that it coasts a little more freely.
I wonder if that started happening to the previous owner after first service and he figured something bad was wrong and sold it. Strange that it would just start now.
jojo87
Re: Dragging
Post by jojo87 »
It's actually really annoying,
never happened in the past 2 months of having the Bike,
only started the other day,
some times its a little worse than others,
rev, let go, and i'll actually go forward abit,
sometimes its not as bad....
just weird how its only now all of a sudden.
