pcx psi
Re: pcx psi
Just curious, I'm wondering if you received an Owner's Manual with your PCX? There's a lot of helpful info found inside of it.
The manual will tell you to set the front tire at 29 and rear at 33 (when you ride "alone.")
There are other threads on this topic that can be found using the Search button at the top right of each page. Keep those tires inflated. Ride safely!
Re: pcx psi
alright I found it lol I forgot I had thatWhiteNoise wrote:Just curious, I'm wondering if you received an Owner's Manual with your PCX? There's a lot of helpful info found inside of it.
Re: pcx psi
Top avatar under the circumstances
Re: pcx psi
^^ Glad you like
At this moment, those dudes should be skating Roads are icy!
Re: pcx psi
I typically run a little higher, maybe 31 on the front and 39 on the rear(I'm fat). Reason being that air seems to eventually leak out about 4 psi below recommended values in about a month or two. My Tire Pressure Sensor doesn't seem to work properly, so I'll probably swap those dead weights out, and it might help with my leaky tires.
I'd probably still top off a little as I noticed my mpg dropped slightly with lower pressure.
- Urbanfreestyle
- Year: 2014 (UK)
Re: pcx psi
I just checked mine after reading this..... Glad i did!
Front: 18psi
Rear: 25psi
That would be why it was riding like crap.
Front: 18psi
Rear: 25psi
Honda PCX 125 ESP (Black)
Re: pcx psi
I've done worse that I'm still embarrassed about. Are you using the rag around the front brake lever trick to "bleed" the brakes?Urbanfreestyle wrote:I just checked mine after reading this..... Glad i did!
Front: 18psi
Rear: 25psi
- RideLondon
Re: pcx psi
What's the trick?
- Urbanfreestyle
- Year: 2014 (UK)
Re: pcx psi
Not changed my pads or needed to bleed them yet
