Looking to buy a 2015 Honda Forza w/ ABS
- Year: 2013 PCX
What should I be looking for on this particular model? It’s only got 2000 mi on it. I know there was a recall of sorts, but I’m not sure what it was even for, or if it could be done after purchase. Any thoughts would be much appreciated.
- E. Foster Salsbury
- Year: 2015 NSS300A
Re: Looking to buy a 2015 Honda Forza w/ ABS
Call your local Honda dealer with the VIN and see what they say?
I would change the oil and filter and WFO everywhere I went!
Salsbury
Also change coolant and brake fluid.
Check for...
Leak from waterpump tell-tale
Rear brake light switch on left lever
Rear brake dragging/excessive pad wear
Knackered clutch bearings
Front axle pinch bolt not seized
Check for...
- Color: silver
if you wernt 1000 miles away from the dealer theres a 2015 new old stock near me for 3999
- Year: 2013 PCX
Thanks for the tip. I ended up getting it for $2500 and it is in like new condition. It ended up being purchased new in Sept 2017. I changed all the fluids and put a windshield on and riding in style now.
- Office Minion
- Year: 2018
- Color: Dark Pearl Blue
What windshield did you get?
2018 Dark Pearl Blue PCX150
2014 Glowing Red Forza 300
- Year: 2013 PCX
Givi D1123ST. I took off the decorative panel and put electrical tape on the backside of it where it contacted the windscreen because it was creaking. No more noise.
- Office Minion
- Year: 2018
thanks jburner... I have that same screen waiting to go on.. maybe I'll put some tape or weatherstrip on to start with.
