speedo issues
speedo issues
Honda pcx 125 esp 2013 model
Speedo recently started failing on and off as seen in vid(its got worse, now its more off than on) .now the engine warning light comes on when engine has warmed up(not sure if its related to speedo issue but the issues seemed to start at the same time).
the 1st thing i tried was a brand new speed sensor but it did not resolve my issue
Any ideas people i'm stuck
here is a vid showing the issue
https://www.youtube.com/watch?v=PUhF0mQ ... tml5=False
cheers
cheers
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
- Year: 26 adv 160
Re: speedo issues
Check all the connections behind the dash and gauges...get some electrical spray at a radio shack type store.
Re: speedo issues
Which light exactly, what colour?buddy1976 wrote:the engine warning light comes on when engine has warmed up
Re: speedo issues
Its the lgiht that comes on for a second when you turn the ignition i think its amber i'll check when i return homegn2 wrote:Which light exactly, what colour?buddy1976 wrote:the engine warning light comes on when engine has warmed up
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: speedo issues
its a wiring issue near the rear suspension chafing. Mine was fixed under warranty by honda .
Re: speedo issues
Did you also get the warning light?rebrab842 wrote:its a wiring issue near the rear suspension chafing. Mine was fixed under warranty by honda .
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: speedo issues
No warning light but i was told that the wiring is chafing when the suspension goes up and down i'm 17 stone so it might have something to do with that.probably doesn't stress the wiring if your lighter.your ecu has probably picked up the fault code mine never did.
Re: speedo issues
Thanks for your replys will try stripping the wiring down on my next day off
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: speedo issues
If it is that then this is a top quality post
Re: speedo issues
good call. after stripping down the rear harness and using my multimeter to test each wire going to speed sensor it turned out to be a broken wire.rebrab842 wrote:its a wiring issue near the rear suspension chafing. Mine was fixed under warranty by honda .
Cheers rebrab842
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: speedo issues
WOW! fastest solution for what I thought would not end well. Sometimes you just win, as for my speedo I don't wear it as much as I used to
Re: speedo issues
homie wrote:WOW! fastest solution for what I thought would not end well. Sometimes you just win, as for my speedo I don't wear it as much as I used to
Wear?
Re: speedo issues
Budgie smugglers.
Re: speedo issues
gn2 wrote:Budgie smugglers.
Re: speedo issues
Only when drinking Southern Comfort at the beach.
Re: speedo issues
gn2 wrote:Only when drinking Southern Comfort at the beach.
German ancestory?
- babisbabou
Re: speedo issues
can you be more specific on to where the cable was cut off? maybe a picture available? tnx!
pcx 125 2011
enjoy :
[youtube]https://www.youtube.com/watch?v=_KVkpi14REk[/youtube]
enjoy :
Re: speedo issues
For those of you who would like to protect certain areas in the wiring bundle from chafing I would like to suggest that you invest in some silicone tape. You can find it online or in many stores. At Walmart it is in the plumbing area.
I use it to wrap wiring bundles in areas where I have worked on the wires but can't get heat shrink on it, especially if it is in a bundle. It comes in a roll that is usually 1 inch wide. Cut pieces down to 1/2 inch wide for easier handling. You have to stretch the tape as you wrap it. It sticks to itself. Only itself.
I also just bought a bottle of liquid sealer but I haven't tried it yet so I can't give any recommendations. Just make sure when you do any electrical work on your bike that you seal the area back to a somewhat waterproof condition, especially if you ride in the rain.
- rvkssl
- Color: Pearl white
Re: speedo issues
Any pictures of the repaired wiring loom?
- babisbabou
Re: speedo issues
So an update ! My wires were cut off too, i extended about 5cm all 3 wires and also changed the speed sensor cause is was tosted Everything works perfect on the speedo.
pcx 125 2011
enjoy :
enjoy :
