What's changed on the 2017?
cocteau2x
Color: Blue
Post by cocteau2x »
Does anyone know where I can find a quick list of things that have been changed on the 2017 model vs the 2016? Has anything important changed in the engine or transmission?
Am I safe to buy rollers/belts/variator/clutch/etc etc etc .. while consulting the specs for a 2016?
Most info I find on the web is actually the same article just reposted and its mostly advertising fluff.
They label the 2014-2016 as version 3 ... can I assume that 2017 will also be a version 3?
Thanks for your help as always.
Re: What's changed on the 2017?
It seems for the european market, the major and perhaps only real change is the introduction of the keyless ignition, not sure of other changes. Someone posted yesterday, on their 2 month old brand new '17 Forza 125, the battery in the key fob run out in 2 months use (it seems the led flashes when the battery is getting low to remind you to change it). Would rather have ABS on the PCX than keyless ignition.
