Hi.
My bike is currently in the process of being fixed and now i am renewing the ignition.
It is a 2016 model bike, i am about to order the ignition now but since the scooter was stolen the wiring was all cut.
So now i need the part from the wiring loom that will attach to the ignition wiring?
Does anyone know where i will get this part from and what is it called?
I will have to fix that part to the wiring loom as i phoned up honda and they are saying i need a full wiring loom and i basically need to fix this plug to the wiring loom.
Thanks.
Help needed regarding ignition?
Re: Help needed regarding ignition?
Have you tried a motorcycle breakers. That would be my first choice
- DAB
I think it may help if you could let us know your location.paulmclaren wrote:Hi.
Thanks.
Other rides
What DAB said.
Hi Paul, do us all a favor and enter your location in your profile. This will help us to help you.
Just follow the easy directions below my post.
Thanks
Thanks
- easyrider
- Color: blk
Cut the plugs and hard wire it??
