Hi everybody,
After 2000 km an annoying noise from the front started on bumps.
Looks like a faulty silentblock or some kind of rubber squeking on every bump all the time.
I’ve already sprayed almost everything with wd40 with no success at all.
Windshield checked also removed but nothing.
Does anyone had the same problema solved?
Forza 300 2019.
Maybe some rub part i missed on the Metal spider that holds the lights?
I Found just 4 plastic blocks. Did i Miss something?
Thanks in avance to anyone could help.
Rubbing noise/front squeaks on bumps
