Thought i'd put some pictures up of my exhaust which i'll be fitting this weekend.
Its a "Tecnigas 4Scoot" system - they do them for non-ESP and ESP 125 engines (pictured is the ESP version for my LED model).
Its a stainless steel system with alloy end can so shouldn't rust (my main reason for buying) but its apparently a bit more free flowing due to no cat. Noise wise i'm led to beleive it'll only be slightly more noisy than standard although i'll not sure if the torx nut in the rear pipe is a removable baffle...will check that on Saturday.
Best part is the price - the ESP version cost only £169 delivered from http://www.pedparts.co.uk in the UK (non ESP is a little more).
Thoughts? I thought it looked quite similar to the Malossi without the price tag?
Not seen these mentioned on here either so may be of interest to some of you.
Tecnigas have a good name for budget performance system in the 2 stroke 50cc scooter community.
