Verdict:
If you don't spend much time going over 65mph, DO IT, it's a serious performance boost you can feel immediately. If you run mostly 65mph+ or less than 30 mph (residential and freeway), don't do it it's not worth it. The RPM and mileage hit suck on the freeway for negligible results over 65mph, and under 30 mph you've barely had time to run WOT anyway and why didn't you get a PCX?!?
Details:
I use my Forza as a commuter, over 90% freeway in the CA Bay Area: read strong winds and 70mph traffic, and occasionally a comfy 75% speed play bike through the hills when I don't feel like shifting on my motorcycle.
I almost always run a tall Honda screen, and I also have a couple Givi topcases, a B47 blade and a B29. I weigh about 230lbs.
I started tracking on Fuelly right after I did the mod. So here's the measurable stat - and I'll try to remember to post a comparison to stock over the coming six months: 58.4 mpg.
Here's some other fairly concrete observations:
- Acceleration RPM at WOT: 6500
- RPM at MPH approximate:
6500 @ 60 mph
7500 @ 70 mph
8500 @ 80 mph
top speed at 9000 redline (achievable under most conditions): 85 mph
Observations here down are "real world", with traffic on freeways during my commute, on close to flat roads usually with some wind:
Seat of the pants upsides: definitely accelerates *much* faster from about 35-65 mph, the most improvement is there. Noticeably quicker off the line, but not as awesome as the "midrange" where the stock variator is holding the rpm around 5.8K or making the transition to the final locked gear... over 65mph I'm not sure it helps at all to be honest.
Seat of the pants downsides: I would guess I've lost something like a solid 500+ rpm in the "locked" final gear, where I recollect I was running closer to 7K rpm at 70, 8K at 90, etc. Top speed remained about 85 (at about 8.5K rpm) but I could never get to redline... This means much more frenetic and strained freeway "cruising" if you could call the SF Bay Area commute that. Which you can't.
So why am I going back to stock? Because I really live on the freeway with this thing and 500+ rpm when redline is that close is not worth the acceleration to lose. Frankly you can really feel the acceleration. But I've got real bikes for that. Also, I would guess I'm losing 2mpg but we'll see. I also think the B47 costs me 1-2 mpg at 70 mph as well, but I don't need it for work so I usually run the smaller topcase and I don't think that costs me anything in mpg, and lets me store my lunch box, laptop and ... err man-purse a little easier.
