2016 Forza ABS Wheel Schrader Air Valves
Cactus
Year: 2016 Forza
Post by Cactus »
I have a 2016 Honda Forza,
After the black wheel air value stem cap is removed there is has a red plastic insert on the valve stem, it has a center hole with a small diameter, the regular Schrader air chuck and air pressure gauge will not fit it.
Does Honda have there own air chuck and air pressure gauge.
What do you do…remove the red plastic insert…
Year: 18 300 xmax
Re: 2016 Forza ABS Wheel Schrader Air Valves
Remove it, Honda valves are nothing special....
Glen could that red plastic insert be the small o-ring that lies within the valve stem's cap? Tiny as it maybe, it sometimes sticks on the valve stem itself. I've even seen them fall out of the cap when their old and dry (that's not the case here).
WhiteNoise wrote:Glen could that red plastic insert be the small o-ring that lies within the valve stem's cap? Tiny as it maybe, it sometimes sticks on the valve stem itself. I've even seen them fall out of the cap when their old and dry (that's not the case here).
True but on both though?
This is all very strange. A picture would really help.
Cactus
Year: 2016 Forza
Post by Cactus »
I just looked at the Online Part Fiche, the Front and Rear wheels only show the Triton Air Valve.
Cactus wrote:I just looked at the Online Part Fiche, the Front and Rear wheels only show the Triton Air Valve.
?? I’m lost. (Graco) Triton is an air valve rather than a type of stem valve?
It’s just going to be a schrader. Post a picture?
Alrighty, I'm getting really confused now. Our scoots come equipped with schrader valves (like most vehicles). What is this about triton - The manufacturers valves? :roll:
This? http://www.tritonvalves.com/listproduct ... ory=VALVES
Year: 18 300 xmax
Triton is a brand, like Honda
Schrader is a type, like scooter.
Cactus
Year: 2016 Forza
Post by Cactus »
The red insert is from the inside of the plastic value cap, I will
push it back in, it was from the rear wheel, the front wheel was fine,
look into the plastic value cap and you could see the red insert.
Thank for the help...
Ah, so I was right after all. Cheerio then
