Some bike engines were designed without a head gasket. Other bikes have removed them as it's supposed to be increase compression, so it can work.GeorgeSK wrote:I wonder if they told you the lack of head gasket just to mollify you. Would the scoot work AT ALL without a head gasket? And wouldn't there be a fair bit of white vapor in the exhaust, since the head gasket is what is supposed to keep the coolant from getting to the combustion chamber?
Oil leak
Mister Paul
Re: Oil leak
springer1
Re: Oil leak
Wouldn't the engine suffer from knock/ preignition given then increased compression ratio unless the OP was using a seriously high octane fuel? Since a head gasket isn't normally a thin material, rather thicker - wouldn't it's absence have a noticeable effect?GeorgeSK wrote:I wonder if they told you the lack of head gasket just to mollify you. Would the scoot work AT ALL without a head gasket? And wouldn't there be a fair bit of white vapor in the exhaust, since the head gasket is what is supposed to keep the coolant from getting to the combustion chamber?
Mister Paul
Re: Oil leak
Update:
Honda UK offered me a year's additional warranty. I said that I was concerned about the resale value of the scoot and any future issues that might appear at some time from running the engine for 1800 miles with no head gasket. They refused to replace the engine and said it would be fine now. I pointed out that an extra year's warranty would mean me being committed to more expensive servicing during that period. Honda UK acknowledged this and said that they'd give me one free service.
The local dealer didn't think this was sufficient and thought that Honda should give me a service package for extra peace of mind. Honda refused. They did send me a nice hamper at Christmas by way of apology.
