WhiteNoise wrote:That looks Really Sharp Phil! I hope you'll give it a worthy try before you decide. Ya know, It will look even better on your scoot, a keeper appealYou could switch 'em out when you want?
I'm trying to figure out the material used...textured vinyl? Is it non-slip? Do you know If they used S.S. staples? More or less foam than stock seat? Did the mounting line up ok? Same as stock....or better?
It's good to read that you have gotten comfortable with the stock seat, but a shame that you're now in a quandary over the newbieGood luck & thanks for sharing with us.
If it weren't raining today, I would give the new seat a try, but I don't relish the thought of removing the old seat and putting the new one on in a downpour. Tomorrow's weather looks to be a bit better, so will give it a whirl then.Taz wrote:only takes a couple of minutes to switch (undo the 2 bolts and seat pressure switch-you may not have the switch on the US model), so give it a try and see which is best on a long ride!
I bet these guys do hundreds of these seats a year, at least. With those numbers, trial and error alone would eventually result in a job well done.qed wrote:Looks a much neater job than mine tbh
They both appear to offer the same amount of room underneath.maddiedog wrote:Does the custom seat have less room underneath it, or same as stock?
It really doesn't seem to change the seat-to-ground height. Just a heck of a lot more comfortable.Indyglow wrote:Does the new seat change the seat-to-ground height at all? I would love to find a seat that would be about two inches lower to the ground. I'd gladly give up interior storage for a lower seat height.
Thanks!V4 TRV wrote:that looks great
I admit, I probably spent too much on the seat. The only saving grace is that it looks great, quality is really good, and the ride is roomy and comfortable.Cracksta wrote:thats looks good but cant justify to part that much money for one.
Thanks!WhiteNoise wrote:Excellent B4 & After photo's and you gave us a video too! Seat looks awesome on the scoot and it does appear to fit snugger than the stock (profile pics). When you ran your hand over it I could hear the texture of the vinyl, Not smooth. That's a good thing! I can't tell from the photo about the staples but no matter, I'll bet they're S.S.....why would they skimp on them when they did such a fine job with the rest? Another plus, is you get to switch them out whenever you want Or you can make adjustments anytime to either one and Still Ride.
Good job Phil, enjoy it. One certainly doesn't have to wait too long (all of 5 mins.?) to crack a beer when the deed is done! My kinda modcheers!
Thanks!gse123 wrote:Looks great!
