Just took a quick look and bookmarked the page . . ..In scouring the web, this seems to be the best collection of things to buy for the Xmax. Two things you want to look at right away -even if you don't like mods-is this is the auxiliary seat spring and the inner fender. The Xmax throws up a lot of crap in the rain ,the inner fender w/ simple mount stops that. And the seat spring is notoriously weak, this spring it will pop open and stay open as soon as you hit the button
https://taiwanbigscootershop.com/collec ... 300?page=1
I noticed the seat raises "adequately" with minimal effort. You can hear the subtle "release" when you hit the button. It doesn't really look like it's open but it is. There's plenty of access to store helmets and gear . . . it's a huge compartment. As mentioned before I noticed the slots for the "divider" accessory. That said I think I still have some fairly rigid, but thin, black plastic leftover from an old loose leaf binder or something that I'm hoping will be just long enough to fit in there. I can craft it to the appropriate height etc. . .. It's buried somewhere but I'm quite sure I'll find it.
About the lack on an adequate inner fender for the rear tire - I wonder what the engineers were thinking. Was it a cost reduction thing? Was it to allow air flow for cooling purposes? Was it to allow easier access to the engine? Whatever the case my Zuma has better protection from rear wheel road rubbish sling than the XMax does. I don't really plan to ride it when it's inclement because I can rely on my Zuma 125 for the around town errands despite the weather . . . within reason. . .or take the cage. However, I may put my "back yard mechanic" portion of the brain into action to see if there is some reasonable and safe solution to the problem. . .if it becomes a problem for me. Or, I can order the accessory.
This morning I checked the extended weather forecast and the first week of March does not look good. February is not over yet . . .. I'm glad I had it delivered sooner rather than later.
