Hi all
I am looking at a pcx later today and will be my first ped, is there anything I should look out for?
Buying a pcx 12
Tommyaweej
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Re: Buying a pcx 12
Other than i"It should run like a clock", no.
Ask if it got its initial oil change at 600 miles or so, and if it has been serviced regularly (at least oil changes). Check wear bars on tires - commensurate with ODO mileage? Handlebars should be very smooth from side to side. If there is a "clunk" or stiff spot in the middle, talk the seller down because you will have some work to do to make that right.
Good luck. Hope you join us.
Re: Buying a pcx 12
Would you mind going into your profile and adding your general location, please? It helps us help you.
By the heading it looks like you are looking at a 2012 PCX. Since there were no 2012 versions exported to the United States, you must be located outside of the U.S.
