does this mean the transmission drum bearing side as gone that should be holding it central or is this normal
pcx 125 2010
				accyuklad
 - Year: 2010
pcx 125 2010
got a issue I just noticed I can wobble my wheel slightly on the rear wheel
				accyuklad
 - Year: 2010
Re: pcx 125 2010
hes video when its off the ground there abit of movement and when I sit the wheel to the ground its makes a gap and still as some play
I know centre stand mounts broke I had to use a wood plank and jack
https://www.youtube.com/watch?v=sTC1GXcyGC4
im guessing this be the bearing on the drum area or is this normal or could it be the bearing on the arm that's allowing it to move
Re: pcx 125 2010
accyuklad,
Please go into your profile and add your general location. It helps us help you better. For example, in the United States there is no 2010 model.
				accyuklad
 - Year: 2010
Re: pcx 125 2010
Is there a chance the spindle on the wheel might be put on incorrect called collar 42311KWN900
I only noticed it today when I was doing a service as I brought it 2 days ago second hand
				accyuklad
 - Year: 2010
Re: pcx 125 2010
I'm going to take arm off tomorrow and see why there's movement and check if it's do with the collar as I can't understand why would it move
				accyuklad
 - Year: 2010
Re: pcx 125 2010
Got a feeling it's the axle bearing in the transmission box
Re: pcx 125 2010
I does to innit.
				accyuklad
 - Year: 2010
Re: pcx 125 2010
Hope it's not going to cost alot to repair going to after get a quote
				accyuklad
 - Year: 2010
Re: pcx 125 2010
£50 for bloody 3 bearings and oil seal for the drum side
just hope labour isn't more then £60
Re: pcx 125 2010
If a bearing/bearing collar has to be pressed out and the new one pressed in, that part of labor is usually sent out to be done, so expect that as an added expense in the labor costs.
				accyuklad
 - Year: 2010
Re: pcx 125 2010
Garage going to have a look and see if it actually fine or not and he said it cost 60-80 if it does need doing with me giving the bearings
				accyuklad
 - Year: 2010
Re: pcx 125 2010
I never thought about checking but but on wheel and it was loose
				Brendan
Re: pcx 125 2010
Did you make a mistake here? What is "but but"?accyuklad wrote:I never thought about checking but but on wheel and it was loose
Re: pcx 125 2010
It means the engine is running.Brendan wrote:What is "but but"?
But but but but but but but but but but but but but but but but but but but but but but but but but but but but but.......
Re: pcx 125 2010
Brendan wrote:Did you make a mistake here? What is "but but"?accyuklad wrote:I never thought about checking but but on wheel and it was loose
My brother.
				accyuklad
 - Year: 2010
Re: pcx 125 2010
no stupid phone I had always changes letters lol
post to be the nut
						post to be the nut
