![Surprised :o](./images/smilies/icon_e_surprised.gif)
Hence, I ordered a new stator and eventually a regulator/rectifier. It was during a time when I had a lot of irons on the fire and not much time for anything else.
After months of delay I finally got to working on it this past week and finished up today.
The battery took a full charge (solid green light on charger), the oil was swapped out (left filter in because it was only about 500 miles since my last oil change), and I began with first replacing the regulator/rectifier. I threw the dice and hoped that the new component would do the trick and fix the charging problem I was having. As luck would have it seems it was all I really needed.
Foolishly I spent $$$ for a replacement stator that I guess I don't need after all. That said it goes into the drawer for later use if ever needed. The KLR is running and I'm happy . . ..
The first time the system failed I had put about 25 miles or so on the machine riding at dusk. I started to notice things going dim and the turn signals were cycling much slower. This was all on a new battery last year too.
So today I did about a 35+ mile ride. Some miles around town to see how things were going and then out of town. There was no change in the lighting characteristics. Using turn signals with the brake light on didn't make any difference from start to finish. The neutral light characteristics remained constant. I even checked the headlight brightness in the garage after I got back and it was fine on high and low beam. All on the same battery I had bought new last year and was the victim of the previous charging system failure.
As an aside, I had to stop for some errands and the starting motor showed no "weakness" or change in enthusiasm when getting underway again. The engine eagerly fired right up.
The signs seem to point to a successful endeavor. I am cautiously optimistic the problem is solved. Short of taking it for a hundred miles or so I'm fairly confident at this point I'll be OK.
Lesson learned? Yes . . . study up on how to analyze a charging system and get a proper tool for it. Just guessing and throwing money at swapping parts is better left to dealerships. But at least you can blame them instead of yourself.
Here are some pics I took today. This is after I got back from the ride. I have the old regulator/rectifier in hand and the box was for the replacement that's now installed and seems to be working fine.
