Which clutch pads do I need/want? Should I change springs??
grndslm
Re: Which clutch pads do I need/want? Should I change sprin
Post by grndslm »
gn2, that link doesn't help in any way.
IN OTHER NEWS.... I haven't really had much time to play with my PCX this weekend. But I went ahead and ordered new clutch assembly, new belt, and skipped the clutch pack (pads + springs) since they should last another 10k or 20k miles.
What I did add to my order (that wasn't part of my original plan) is this new "racing clutch bell" that I was able to get for $42 since I had $3 of eBay Bucks ---> https://www.ebay.com/itm/KAO-GY6-125-15 ... Sw3~tZbk0i
There's a few others I was considering, but that one most matched that $200 one from Japan. VERY grippy interior surface *and* holes. Some of the ones I was looking at I couldn't tell how grippy their interior surface really was. Willing to bet this KAO is the grippiest! Now, I just hope it fits. I believe the spline pattern will match, but the stock bell has a lip on the "open" or "bottom-end" of the bell. Some of these others don't have that lip, and I'm not sure if that would be a problem or not. Here's the others I was considering...
- https://www.ebay.com/itm/GY6150-125cc-R ... Swhf1ZnkAS
- https://www.ebay.com/itm/SCOOTER-G0-KAR ... SwivlcZU4i
- https://www.ebay.com/itm/KC-GY6-125-150 ... SwLEtYmgdP
- https://www.ebay.com/itm/Performance-Re ... SwALFbOD5W
- https://ncystore.com/ncy-clutch-bell-gy6
- https://www.ebay.com/itm/SCOOTER-150CC- ... SwHEhZ-ffB
grndslm
Post by grndslm »
you you wrote:Use full throttle with the brakes on. Slowly release the brakes. Repeat half a dozen times
This definitely works!!!
Wow.
Wow.
Cheersmedears :D
