ABS Buzzing
Yorkie150
Year: 2018/19
Color: RED
ABS Buzzing
Post by Yorkie150 »
Ref my last post on odometer problems.....
I disconnected the battery while undertaking odometer settings problems ( now resolved ) and reconnected when completed.
Took the PCX out for a good test run today and noticed that the when the abs light goes out I hear a small buzzer sounding ....just after I start up and ride away ....
didn't do this on the way home the other day ......Im not using the idle stop thing.
Docscooter2010
Color: PCX Black
Re: ABS Buzzing
Post by Docscooter2010 »
If you look further down the page you will see 2 topics on why your ABS is buzzing . Give them a read it will all become clearer.
Yorkie150
Year: 2018/19
Color: RED
Re: ABS Buzzing
Post by Yorkie150 »
apologies...im not forum savvy......first time user....can you send me a link ?
many thanks
*** EDIT ****
Found it now....thanks...looks like nothing to worry about - just annoying :)
Re: ABS Buzzing
Re: ABS Buzzing
I read the 1st post as you had not noticed the buzz until you disconnected the battery and did work, as it should have been there from day one. Ah well, seems all is well and as should be?
Yorkie150
Year: 2018/19
Color: RED
Re: ABS Buzzing
Post by Yorkie150 »
yeah , I never noticed the buzzing until I disconnected/reconnected the battery...then gave it a good run...Perhaps the battery charge level was low as the scooter had been stood in a garage for quite some time prior to me purchasing it....I have now fitted a connector direct to the battery for an Optimate charger / conditioner so hopefully all will be all now :)
