High Revs at low speeds
Variant
- Color: Blue
Just brought a 2017 pcx150 with 3500km on the clock here in Thailand. Looks very clean and stock but it revs high at low speeds. Im a newbie with this type of thing but maybe previous owner dropped in some light weight rollers/sliders of some such? It has really good acceleration. I would love to make it so it has low rpm at low speeds, not interested in high speed very often, I like to ride rather slowly, would prefer the quiet cruisey slow ride...
Re: High Revs at low speeds
Step 1: Get a tach to see if its actually reving high
Step 2: Check and see what size weights you have
step 3: Install heavier weights if you want lower RPM's
Whats your max speed?
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
Variant
- Color: Blue
Thank you, yes I studied about cvt rollers quite a bit last night and am thinking along the same lines now. It really is quite annoying at low speeds compared to the low rpm of other scooters or even the pcx I rented a few months back. I havnt gotten to top speed as yet but it accelerated strongly up to 80kmph and seemed like it would take it's own good time after that. Im in Thailand without tools so that and the language barrier does complicate things a little. I will look online and see it I can find a tach. The place I brought it is also a mechanic so hopefully he can weigh the roller (if I can communicate the concept!) I think the stock roller weight is 18.5g?
I think the stock ones are 15gram roller weights. You can check and see if you can weigh them. Make sure they are installed correctly. Also check your clutch assembly. It could be stuck.Variant wrote:Thank you, yes I studied about cvt rollers quite a bit last night and am thinking along the same lines now. It really is quite annoying at low speeds compared to the low rpm of other scooters or even the pcx I rented a few months back. I havnt gotten to top speed as yet but it accelerated strongly up to 80kmph and seemed like it would take it's own good time after that. Im in Thailand without tools so that and the language barrier does complicate things a little. I will look online and see it I can find a tach. The place I brought it is also a mechanic so hopefully he can weigh the roller (if I can communicate the concept!) I think the stock roller weight is 18.5g?
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
- alx123
- Bangkok Rider
- Color: Fast White
Might not be just the rollers. Sounds like the entire variator was changed into an aftermarket one where topend is the priority. Plenty of aftermarket variator sold here in Thailand and Thais love them as they love to WOT in the highway.
I'll go to Honda and tell them you want OEM parts in there.
