Hello all,
On the back of my scooter the paint has chipped quite badly and i am looking to fix this..
Has anyone any suggestions of what paint and prep to use?
Reason i need this fixed as after every wash it keeps chipping further..
Thanks
I am not crazy. Crazy people don't know they are crazy, whereas I know I am crazy, so therefor I am not crazy!
I’ve been painting cars and bikes for years, and if it was my bike, I would take the piece off , sand it completely down and re-spray it. A body shop can do this and match the paint for $150-$200. If you do all the sanding work first, it might just be about $100. And alternative is you could vinyl wrap the part for less than $25 that would match quite well. If you want to do it yourself, it would take Duplicolor plastic primer, base color, and clearcoat. Three different paints. All avail at your local auto parts store. The paint schedule would be:
Sand clean with 80 grit then 400 grit wet dry paper, acetone wipe.
Two coats primer
Two coats base color
2-3 coats clear
Polish to gloss with a finishing polish like meguire’s 205.
Or just wrap with 3m 1080 gloss black wrap. Sand clean, acetone wipe and wrap it.
I don't think I have ever seen paint chip off on that particular part. It must of had a rough time. If you are cheap you can put some reflective tape over it and call it done, but if I owned that bike I would replace the part. It isn't expensive, nor is it difficult to replace.
Welcome to our forums ahulleman!
Go for the Replacement part: @ Revzilla located in PA. I have purchased many items from them over the years. Thumbs up!
This link will take you where your part is. (You want some milk with those cookies? I'm just feeling a bit silly this Sunday, that's all)
