2022 PCX Alternator Output
- airhead83
- Year: 2025 US
- Color: Pearl Gray
Just that. Can anyone tell me what the PCX's rated alternator output is?
Apologies if I missed it in previous discussions, but I tried and failed to get a definitive answer.
I wouldn't think much, but enough to carry heated Oxford grips and a heated vest would be helpful.
Re: 2022 PCX Alternator Output
No issues with that at all. I have a 65watt headed jacket and it doesn't even notice it when its plugged in.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
Once you start to add stuff like amplifiers for sound systems and stuff like that you might to start having issues. But heated grips and vest is no problem.
I would still recommend if possible to keep it on a tender as much as possible. Keep that Battery nice and healthy.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
- airhead83
- Year: 2025 US
- Color: Pearl Gray
I have the honda grips fitted from new on my 2021 (current model) and also run a gopro and a phone charger and have done for 3 years nearly. It's never missed a beat
CBR1100XX blackbird (modified), CBR929RR Turbo, CBR600F Sport (modified), several beta trials bikes and endurance bikes
- power-full
- Year: 2010
- Color: preta
I have the PCX from 2011 and I connected it to an existing plug below the pressure gauges, I connected the 12v LED kit, 35wx2 6000k, and the Oxford heated grips... I also have the 4 flashing button on this model connected to that same plug. I haven't had stress until today.
- airhead83
- Year: 2025 US
- Color: Pearl Gray
Re: 2025 PCX Alternator Output
Per Helm's 2025 Honda PCX's Service Manual:
The 2025 Honda PCX has a triple-phase alternator with an output of.67KW @ 5000rpm. That should convert to 670-Watt capacity.
I'm skeptical. Are my conversions wrong or am I overlooking something else?
My 2024 Suzuki GSX250R's service manual listed an output capacity of 400-Watts at 5000 rpm.
I had zero riding all winter with heated grips, heated vest, and front auxiliary LED lighting.
Since there were no major changes for the 2025 model, I'm inclined to believe all reasonably current PCX models use the same charging systems.
If 670-watts is correct, I'm pleased.
- airhead83
- Year: 2025 US
- Color: Pearl Gray
Sorry... I had 'zero problems' riding all winter with heated grips, heated vest, and front auxiliary LED lighting.
As expected. lol
Yeah even if its 670Watt output at 5k RPMs, you are never that low of RPMs ever cruising so the output is even higher than that. Maybe more in the 1k watts range.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
