15-50 Oil
15-50 Oil
I am about ready to do the first service on my PCX. I have some Mobil 1 15W-50 Fully Synthetic left from my Harley that I would like to use. I know 10W-30 is recommended, but will I be ok using the 15-50?
2013 Honda PCX 150
Re: 15-50 Oil
The thing that tickles me about this question is that you put fully synthetic in a Harley.
Hilarious.
Hilarious.
Re: 15-50 Oil
OMG WTH was I thinking. I did not ask the great gn2 what oil to put in my Harley. I have read many replys from gn2 and I must say you are a real piece of _______
2013 Honda PCX 150
Re: 15-50 Oil
Oil is cheap. Use the recommended 10/30. I bought a few quarts of HP 4S Honda stuff for like 9 bucks each. That will last me 2 seasons.
Use the 15/50 in your Toro
Re: 15-50 Oil
jlhog wrote:OMG WTH was I thinking. I did not ask the great gn2 what oil to put in my Harley. I have read many replys from gn2 and I must say you are a real piece of _______
Rood
Re: 15-50 Oil
Indeed, you ended up with a harley so it looks like the thing you use for thinking with is prone to major malfunctions.jlhog wrote:OMG WTH was I thinking.
Re: 15-50 Oil
OK I will fill in the blankgn2 wrote:Indeed, you ended up with a harley so it looks like the thing you use for thinking with is prone to major malfunctions.jlhog wrote:OMG WTH was I thinking.
SHIT
2013 Honda PCX 150
- Year: 2013 PCX125esp
Re: 15-50 Oil
I don't know. But I'd still use the recommended grade, because I do know that I don't know better than the manufacturer.jlhog wrote:will I be ok using the 15-50?
We're talking about less than a litre, anyway - just get some 10W30 bought
Just my two-penn'orth.
Re: 15-50 Oil
A touch unacceptable too. Gn2 has his own opinions and boy do we know them. He never is personally insulting.jlhog wrote:OK I will fill in the blankgn2 wrote:Indeed, you ended up with a harley so it looks like the thing you use for thinking with is prone to major malfunctions.jlhog wrote:OMG WTH was I thinking.
SHIT
An apology for taking things too far would be nice
Re: 15-50 Oil
you you,
This here was insulting to me:
gn2 is rude in a lot of his replies. Maybe you need to get used to his flavor of humor. But I will not offer an apology of any kind. I read that line as him saying I am some sort of dumb ass. All I asked was if using 15-50 oil would be ok to use as I have some on the shelf. I know 10-30 is cheap and I can just get some for the PCX. I guess I throw the 15-50 in the trash.
2013 Honda PCX 150
Re: 15-50 Oil
Exactly, use it to top up the harley.jlhog wrote:I guess I throw the 15-50 in the trash.
It was not my intent to cause you offence, just a mild jocular leg pull which a big butch harley leather joy boy pirate should easily be able to cope with.
Re: 15-50 Oil
Harley riders loose their sense of humour after around the 20th breakdown
Re: 15-50 Oil
Wow, I just tuned in. What the hell happened here? This thread is a little "ruff" around the edges and a bit direct. Ouch.
A question about oil.......and this is outcome? Hold on, Wait........I gotta get my boxing gloves.
jlhog, I say just use 10-30. Guessin' best advice to give on any forum is to roll with the punches. No need for "anyone" to get nasty, life is too short. Getting use to everyones personalities is key (did I spell that right? gn2 will correct me if I am wrong
Or, just ignore threads ya don't like and move on to one of the other 1,000 + threads.....
(as you you would say: "simples")
Have a good day everyone
and ride what cha' like (safely)
- valuesynthetics
Re: 15-50 Oil
You may get away with using a heaver weight oil for one change and notice nothing immediately other then slightly worse fuel economy. But Honda has the engine spec to run on 30 weight oil so we can't rule out possible issues. It would also void your warranty if they discover the heaver weight oil was used in a warranty repair situation. I dont know the exact technical properties of the Mobil 1 15w-50, but I can show you the comparison for AMSOIL's Motorcycle 10-30 (recommended for our PCX) & the available 20w-50 Motorcycle oil. You'll see the Viscosity numbers are very different & could lead to higher stress in our engine.jlhog wrote:I am about ready to do the first service on my PCX. I have some Mobil 1 15W-50 Fully Synthetic left from my Harley that I would like to use. I know 10W-30 is recommended, but will I be ok using the 15-50?
Good Luck!
TYPICAL TECHNICAL PROPERTIES
AMSOIL High Performance Synthetic 10W-30 Motorcycle Oil (MCT)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
11.1
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
72.0
Viscosity Index (ASTM D-2270)
147
Flash Point °C (°F) (ASTM D-92)
242 (468)
Fire Point °C (°F) (ASTM D-92)
254 (489)
Pour Point °C (°F) (ASTM D-97)
-46 (-51)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
5.10
Four Ball Wear Test
(ASTM D-4172: 40 kgf, 150°C, 1800 rpm, 1 hr), Scar, mm
0.40
Total Base Number
11
High-Temperature/High-Shear Viscosity,
(ASTM D5481 @ 150ºC, 1.0 x 106 s-1), cP
3.5
AMSOIL SAE 20W-50 Synthetic Motorcycle Oil (MCV)
Kinematic Viscosity @ 100°C, cSt (ASTM D 445) 20.4
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 162.2
Viscosity Index (ASTM D 2270) 147
Pour Point °C (°F) (ASTM D 97) -40 (-40)
Flash Point °C (°F) (ASTM D-92) 238 (460)
High Temperature/High Shear Viscosity (ASTM D 5481 @ 150°C , 1.0 x 106 s-1), cP 6.1
Four Ball Wear Test (ASTM D 4172 @ 40 kgf, 150°C, 1800 rpm, 1 hour), Scar, mm 0.4
FZG (ASTM D 5182), Load Stage Pass (Wear in mm) 13 (0mm)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 3.7
Foam (ASTM D 892, Sequence I, II & III) 0/0/0
Shear Stability Kurt Orbahn (ASTM D-6278), % viscosity change 120 cycles 0.25
Rust Test - Humidity Cabinet (ASTM D 1748) No Rust, Pass
Total Base Number 11.1
-Jacob
PCX150
Nashville, TN USA
AMSOIL Independent Dealer
www.valuesynthetics.com
PCX150
Nashville, TN USA
Re: 15-50 Oil
Now that is what I call an answer to my question, Thank you
I am going to put some Valvoline 10W-30 in the scooter. Maybe some day I will find a use for the Mobil 1.
valuesynthetics wrote:You may get away with using a heaver weight oil for one change and notice nothing immediately other then slightly worse fuel economy. But Honda has the engine spec to run on 30 weight oil so we can't rule out possible issues. It would also void your warranty if they discover the heaver weight oil was used in a warranty repair situation. I dont know the exact technical properties of the Mobil 1 15w-50, but I can show you the comparison for AMSOIL's Motorcycle 10-30 (recommended for our PCX) & the available 20w-50 Motorcycle oil. You'll see the Viscosity numbers are very different & could lead to higher stress in our engine.jlhog wrote:I am about ready to do the first service on my PCX. I have some Mobil 1 15W-50 Fully Synthetic left from my Harley that I would like to use. I know 10W-30 is recommended, but will I be ok using the 15-50?
Good Luck!
11.1
72.0
147
242 (468)
254 (489)
-46 (-51)
5.10
Four Ball Wear Test
0.40
Total Base Number
11
3.5
2013 Honda PCX 150
Re: 15-50 Oil
Throw it in your mower, power washer, ect.
I would never consider that in as fine-tuned machine like a small motor like the PCX to save what, 2 bucks
Use it light a campfire, or in your lawn mower. I have many quarts of specialty oils, but would never use a weight., just because it's sitting around the house.
- Color: WHITE
Re: 15-50 Oil
I think you can put your existing 15w50 to a use in the PCX if you mix it with lighter weight oil.
I would just mix it 50/50 with Wal Mart Supertech 10w30 or even 5w30 full synthetic. Those oils are great but have the stamp of being energy conserving. But with a mix they will make a great blend for the use in the PXC.
I've put 18000 miles on the Metro using half and half mix of wal mart supertech 10w30 and valvoline 20w50 both full synthetic.
Re: 15-50 Oil
Honda recommends 10w30 with MOLY(specifically HP4M). Make sure you get oil with moly in it. My fuel mileage dropped from 93 to 82 because they didn't use the right oil for the last service.
Re: 15-50 Oil
Hoy owt in. It's a honda
