you buy a plastic oil measuring jug. failing that you put in a bit under the right amount and check the oil strictly according to the procedure as described in the manual:logepoge1 wrote:I mean how do you tell when you are putting too much in?
1. let the engine run for 5 minutes until it is completely warmed up
2. turn it off and put it on the center stand
3. wait 2-3 minutes and check the oil
if it is a bit low, add a bit.
