Engine stalled
- logepoge1
Engine stalled
I was turning left from a stoplight and when I tried to take off I believe the engine stalled. I was twisting the throttle and was barely revving. Finally it took off like normal and I rode just fine. Gonna bring by dealership and ask what they think problem is
Re: Engine stalled
Maybe you didn't give it enough throttle or didn't release the brake?
Re: Engine stalled
Write to Honda for a refund. It's the only way to be sure
- logepoge1
Re: Engine stalled
I didn't buy it from the dealership. I bought it used but the 2 year extended warranty transfers. I'm gonna check spark plug and stuff but it is dangerous when this stuff happens when I am turning from a non intersection road onto main road and it just stallsyou you wrote:Write to Honda for a refund. It's the only way to be sure
Re: Engine stalled
Can you make it happen at will? Or is it once in a blue moon type of things? Either way get it checked out before it gets worse. Good luck to you.
- logepoge1
Re: Engine stalled
Hasn't happened again I don't really understand what even caused it. Have taken off at lights plenty of times with no issues~Cheap_Ride~ wrote:Can you make it happen at will? Or is it once in a blue moon type of things? Either way get it checked out before it gets worse. Good luck to you.
- OriginalRocket
Re: Engine stalled
Check spark plug gap.
Had this happened to me, could actually replicate it too. Fast blip of throttle while idle right between the piston firing. I think it was flooding the engine. But my plug gap had expanded. Can't replicate any longer.
- logepoge1
Re: Engine stalled
Is there an instruction here to do this and how do I do this?OriginalRocket wrote:Check spark plug gap.
- OriginalRocket
Re: Engine stalled
The owners manual has all you need. It's a small area to get at, I had a spark plug socket and I ended up turning it with a wrench.
Re: Engine stalled
guys i have the same problem the last two years. it happens to me once a time per 200-250 km.. I have changed air filter, spark plug,I have cleaned the throttle body and today I changed the iacv...it is my last chance.. after that if stalls again, I must check or replace the ecu..my warranty has expired.. i have opened a topic here.. (my pcx stalls under 20km). I describe the ways when my engine stalls..if you have any other idea please let me know..
Re: Engine stalled
Have you checked the valve clearances? That can cause stalling issues in a single-piston engine like the PCX.
- logepoge1
Re: Engine stalled
I haven't done this yet. Will do at 2,500 mile service. Really close to that. I bought the feeler guages the other day so I have what I need. Checking spark plug gap when I go home later and get the right socketsmaddiedog wrote:Have you checked the valve clearances? That can cause stalling issues in a single-piston engine like the PCX.
- logepoge1
Re: Engine stalled
Don't have spark plug socket what size regular socket do I need?OriginalRocket wrote:The owners manual has all you need. It's a small area to get at, I had a spark plug socket and I ended up turning it with a wrench.
- logepoge1
Re: Engine stalled
Socket size?logepoge1 wrote:Don't have spark plug socket what size regular socket do I need?OriginalRocket wrote:The owners manual has all you need. It's a small area to get at, I had a spark plug socket and I ended up turning it with a wrench.
- logepoge1
Re: Engine stalled
If anyone is wondering, it is 16mm. Will be changing it tonight but looks like the tops part of plug that connects to wire was dirty. It only has 1700 miles on it but almost 2 years old so it wont be a bad fix.
Unfortunately, every autoparts store was out of these spark plugs, and that includes Advance Auto Parts who called Oreilly and Autozone for me. I finally went to dealership and paid $7 for plug but wanted to change today
- OriginalRocket
Re: Engine stalled
Yeah these plugs are not common, hard to find, I bought out the entire amazon.com supply when I bought my scooter. They have since replaced supply, but it's very limited.
Re: Engine stalled
