PCX tuning
PCX tuning
Can any one tell me where the restriction on a pcx is also if it has a restriction to the revs i.e ignition
Re: PCX tuning
The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Read this thread if you want to learn more about tuning the beast:
http://hondapcx.org/viewtopic.php?f=9&t=796
Current - 2015 Honda CBR650F
Re: PCX tuning
Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?
Re: PCX tuning
The restriction is that it has a pitifully low amount of powersolo one wrote:Can any one tell me where the restriction on a pcx is also if it has a restriction to the revs i.e ignition
In some ways that is part of its charm
It's not hugely restricted. It's naturally slow
I know this wouln't help you
Re: PCX tuning
Yes....it was sarcasm directed at you. I knew you would not resist responding.you you wrote:Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?
Re: PCX tuning
Slickvic wrote:Yes....it was sarcasm directed at you. I knew you would not resist responding.you you wrote:Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?![]()
Touché
Re: PCX tuning
I've been going through the Performance section and seeing lots of you poo-poo'ing on people's mods. Stop it, or I'll have to prevent you from posting in this forum like I had to prevent GN2.you you wrote:Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?
If people want to mod their PCX for more performance, that's on them. Let them have productive discussions without interfering, please, and encourage their work. It's not your place to offer discouragement.
Re: PCX tuning
maddiedog wrote:I've been going through the Performance section and seeing lots of you poo-poo'ing on people's mods. Stop it, or I'll have to prevent you from posting in this forum like I had to prevent GN2.you you wrote:Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?
Good ahead, it's for the best.
Re: PCX tuning
Good ahead or go ahead? Be clear, man!
Re: PCX tuning
maddiedog wrote:Good ahead or go ahead? Be clear, man!
Oops predictive text and poor eyesight.
Go ahead
Re: PCX tuning
2 out of 2.....should be all sweet in the performance section after that...maddiedog wrote:I've been going through the Performance section and seeing lots of you poo-poo'ing on people's mods. Stop it, or I'll have to prevent you from posting in this forum like I had to prevent GN2.you you wrote:Beast?Slickvic wrote:The on-board PCM module has a rev limiter. I believe that the max RPM limit is 9,600.
Seriously?
Re: PCX tuning
Done. You can still read it, you just can't reply.you you wrote:Go ahead
Re: PCX tuning
maddiedog wrote:Done. You can still read it, you just can't reply.you you wrote:Go ahead
Are you sure?
Re: PCX tuning
Since Clubpcx is gone now, did anyone happen to copy the tuning section to this forum? I was interested in what it said. I know the PCX has restrictions but it is interesting to read about what people have done to get around the restrictions. I have heard that they actually race these scooters over on the 'far side' of the world. (And to them, we are the far side:-)
Re: PCX tuning
you you wrote:maddiedog wrote:Done. You can still read it, you just can't reply.you you wrote:Go ahead
Are you sure?
Re: PCX tuning
Mel46 wrote:Since Clubpcx is gone now, did anyone happen to copy the tuning section to this forum? I was interested in what it said. I know the PCX has restrictions but it is interesting to read about what people have done to get around the restrictions. I have heard that they actually race these scooters over on the 'far side' of the world. (And to them, we are the far side:-)
Now that would be interesting and a bit of "new ground"
Re: PCX tuning
Apparently I failed to remove your permissions.
I'll look into it later. Not willing to mess with it now.
Re: PCX tuning
There genuinely is a Procrastination Society.maddiedog wrote:Apparently I failed to remove your permissions.
It's just about to start its 2009 recruitment drive...
